#1 |
Changing a switched outlet
I have an outlet in my house that is powered by a wall switch. I'd like to have the outlet continuously powered without having to use the wall switch. Suggestions? Thanks!
#2 |
Just call me Andrew
Shut the appropriate breaker off....then remove the switch. Take the two wires that were previously connected to the switch and connect them to each other with a wirenut.
Put a blank cover plate where the switch used to be. Turn power back on.
Andrew |
| Display Modes | |
| Branching off Switched Outlet | BaconK5 | Electrical | 7 | 01-22-2010 06:56 AM |
| Outside: Adding an outlet to a switched light fixture | indigo | Electrical | 9 | 12-15-2009 10:48 AM |
| Adding Ceiling Light From Switched Outlet | vboz5 | General Discussion | 2 | 03-04-2009 01:53 PM |
| Changing an outlet, Grounding Procedure | jamiedolan | Electrical | 15 | 10-12-2008 11:07 AM |
| Adding new ceiling light in place of switched outlet | XavierG35 | Electrical | 2 | 02-13-2008 10:05 PM |
