-   -   Changing a switched outlet (http://www.diychatroom.com/f18/changing-switched-outlet-84339/)
drb753 10-19-2010 11:14 AM
I have an outlet in my house that is powered by a wall switch. I'd like to have the outlet continuously powered without having to use the wall switch. Suggestions? Thanks!
secutanudu 10-19-2010 11:29 AM
Shut the appropriate breaker off....then remove the switch. Take the two wires that were previously connected to the switch and connect them to each other with a wirenut.
Put a blank cover plate where the switch used to be.
Turn power back on.
