Changing Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 12:04 PM   #1
Changing switch
I am trying to change a light switch that controls an outlet. I thought it would be as simple as disconnecting the old switch and then reconnecting the new one with the same configuration. I must have done something wrong. Now the switch seems to control Every light and outlet in the room. The old switch had three black wires connected to it, one of which was hot. The neutral wires were connected with a wire nut in the box, nothing connected to the switch.
imnotaplumber is offline   Reply With Quote
Old 12-16-2012, 12:17 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
You have the feed out connected with the switch leg.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
Changing Light Switch Thermador Oven roztom Appliances 0 06-12-2012 05:29 PM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
