Changing Speed Of Grinder - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 10:09 AM   #1
changing speed of grinder
Guys
I have a one speed "higher speed" (3600 RPM) grinder. I would like to somehow back it down to a much lower speed (1700 RPM) or so to be able to sharpen tools without risk of metal damage due to heat from higher speed.
Is there a way to wire it or an item to add on the power side to only allow so much umph to it so speed is reduced? Ideally I would like to make it variable speed but dont know if possible and will be happy with reduced one speed.
thanks
Gene
MeanGene is offline   Reply With Quote
Old 03-19-2011, 10:43 AM   #2
Rewards Points: 1,418
An AC frequency controller. Intrinsically a signal generator as used for audio testing but constructed to deliver many amperes and probably quite expensive.
Even though a frequency controller has lots of variability, there are practical limits depending on the motor you are running. The lower the frequency the lower the impedance of the motor windings and you run the risk of excessive current draw and overheating.
Old 03-19-2011, 10:53 AM   #3
I figured if it wasnt built variable speed not meant to operate as variable speed
The older I get the better I was
Lennox Fan - Low Speed Only? Bob01 HVAC 11 07-07-2012 01:35 AM
how to build a single phase induction motor sashman Electrical 3 03-31-2011 08:18 AM
angle grinder question itin1200 Tools 8 07-13-2010 08:07 PM
Why do you have to screw in a different wire to change the fan speed? joshoc HVAC 5 06-14-2010 07:32 AM
Two Speed Compressors rjordan392 HVAC 2 08-26-2007 02:32 AM
