Old 10-19-2012, 11:11 PM   #1
Changing Soffit Fixture
Hello,
I am replacing a fluorescent light fixture above the kitchen sink with a pendant light. I will need to attach an electrical box in the soffit to wire the new pendant light. The soffit is 1/2 inch thick (bottom of a cabinet). How do I secure the box into the soffit? Thanks.
BloodyNnuckles
BloodyNnuckles is offline   Reply With Quote
Old 10-19-2012, 11:46 PM   #2
Licensed electrician
A pancake box is 1/2" deep. They are available in both new and old work styles.
Old 10-20-2012, 10:16 AM   #3
http://www.bing.com/images/search?q=...71A800&first=1
Old 10-22-2012, 12:10 AM   #4
Jim and joecaption, thanks for the reply. If I understand correctly, I will attach the pancake box to the bottom of the soffit. I can then run the cable down through the soffit and in through the top of the box. Should the cable be in a conduit from the pancake box back to the wall?
Right now the cable comes out of the wall (no box) and into the fluoresent housing with no conduit. Do I need a box where the cable comes out of the wall? Thanks.
BloodyNnuckles
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing 18 05-29-2012 10:12 AM
Replace outdated fixture with outlet derbydog Electrical 4 12-14-2011 01:53 AM
Installing a pull chain ceiling fixture safron Electrical 16 08-22-2011 06:13 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
Changing Light Fixture - Way too many wires and light wont switch off marapapa Electrical 3 01-13-2006 02:16 PM
