Changing Single Phase To 3 Phase - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2007, 01:35 PM   #1
changing single phase to 3 phase
can i convert home use single phase supply to 3 phase for comercial sunbed. polly. Scotland.
bentaypink is offline   Reply With Quote
Old 12-13-2007, 01:40 PM   #2
Yes. You need a phase converter. There are two kinds:
Solid State phase converters are little black boxes that electronically produce the 3rd phase. They allow 3-phase motors to start on single phase power, but they don't generate the same power as they do when run on 3 phase. These are limited in capacity to a couple horse-power, but are much cheaper than the next kind.
Rotary phase converters use a 3 phase motor to generate the third leg, and electronics to balance the 3 legs evenly. Motors run on this type of converter have all the power as if run on real 3-phase power off the POCO pole. This come in a wide range of sizes, and can be sized to run even very large motors.
I have no idea how all this applies to a non-motor load like a tanning bed.
I'd contact the manufacturer and ask them if you can use their bed on a solid state phase converter, and what size is needed.
NateHanson is offline   Reply With Quote
Old 12-13-2007, 03:01 PM   #3
General Contractor
joasis's Avatar
I cannot see why a tanning bed would be 3 phase. Unless it has an incredible load when on.....are you sure you are confusing 3 phase with 220 volts?
I am not an electrician, but 3 phase power would have no application for lighting, as far as I know.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 12-13-2007, 03:55 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I just love these guys that want to make an ass of themselves by replying with total BS so they can get their ad posted.
Old 12-13-2007, 04:00 PM   #5
I am an electrician and all tanning units are different. If it requires a three phase system your only option is to get an induced thrid phase converter. You don't have a need enough for your power supplier to give you a third phase and they don't have any way of giving it to you. The transformer your house house is supplied from is only set up for single phase power. Please read all the info on your tanning unit because that will define the trans x you will need i.e. 277v,480v,600v ect. most trans x are set for a single voltage application.
wiredog is offline   Reply With Quote
Old 12-14-2007, 10:07 AM   #6
Once fried, twice shy.
elkangorito's Avatar
Ahem....the OP is in Scotland!
I think that Nate is on the ball but please don't even think for one second that the OP knows what POCO is & also be aware that Scottish voltages etc will not be the same as that of the USA.
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
Old 12-15-2007, 12:09 AM   #7
" Euro " electrician
frenchelectrican's Avatar
it possible to get 3 system in Scottland for resdental service.
but the voltage is diffrent than what we have here in UK-Scottland is 240v L-N and 415 L-L
but i dont have the info for getting the Scottland info but i know with French system [ but that diffrent story anyway ]
i am sure the Scottland is pretty much parallel with the UK regulations expect few local issue.
Merci, Marc
Old 12-15-2007, 05:54 AM   #8
3 phase sunbed
thank you everyone for your help. Scotland does have the same electrical supply as the rest of the uk. 240v. The sunbed is industrial and we only run on single phase. You were correct Elkangorito i haven't got a clue what poco means lol.And i hope op doesn't mean old pensioner lol.
Old 12-15-2007, 06:33 AM   #9
Rewards Points: 1,192
Before i read your reply,I thought that was a pretty good idea.I still do.
bobelectric is offline   Reply With Quote
Old 12-15-2007, 12:32 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Then maybe you should take a second and read the forum policy on posting business solicitations on the forum threads. Frankly it's rather annoying to have someone post just to get their ad in front of everyones eyes. As far as the bs about no 3 phase tanning beds and lighting has no 3 phase application...I'm still laughing at that one.
Also remember this op is from Scotland so it makes it more obvious that he had no intention of helping the OP, just his personal interests. If he wants to advertize then buy an ad on the forum in a banner form. Maybe he is just too damn cheap for doing the right thing. Heck why didn't he just open his own thread and give us his life history I'm sure we would all be responsive to that approach.
Old 12-15-2007, 03:23 PM   #11
POCO means Power Company. The electrical utility.
heating element 240 volt single phase geeyathink Electrical 19 02-20-2011 06:57 AM
Converting std 220v/60hz to Single phase 240V 3-wire jryali Electrical 19 03-23-2009 11:06 PM
Single to 3 phase invertors/converters bantanic Electrical 6 02-09-2007 09:20 AM
3 phase electricity J187 Electrical 11 10-26-2006 01:40 PM
