Changing Recessed Lighting Trim? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 08:10 PM   #1
Changing recessed lighting trim?
I have the current trim (see attached) and would like to change to one with baffle trim - do I need to buy another recessed lighting kit that can accommodate it or is this an easy swap?
argh is offline   Reply With Quote
Old 09-06-2010, 08:12 PM   #2
Licensed electrician
Rewards Points: 1,020
Changing trims is just a matter of finding a trim you like from the manufacturer of the housing. Remove old and install new.
Be sure to match the bulb to the trim. Certain bulbs can only be used with certain trims.
Old 09-06-2010, 09:13 PM   #3
This is the one I need, though not a case of them. When I was just at HD, for 5" baffled they only carried Cooper Lighting.
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 7 09-05-2013 07:00 PM
installing recessed lighting trim lwb1 Electrical 1 09-01-2010 09:43 PM
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 05:30 PM
Recessed lighting trim in bathroom? TReally Electrical 2 03-16-2010 08:45 AM
Removing trim from recessed lighting dadaR6 Electrical 3 02-09-2009 02:52 PM
