Changing An Outlet To Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 11:04 AM   #1
Rewards Points: 97
Changing an outlet to switch
I am interested in doing some undercabinet lighting. I was hoping to have it hard wired so that it would run off a switch.
I currently have a plethora of outlets in my kitchen. I was hoping to replace something like this http://www.lowes.com/pd_245843-334-V...facetInfo=GFCI
with something like this http://www.lowes.com/pd_217938-334-T...tInfo=Standard
and then hardwire the under cabs into the switch portion. WOuld that work??
BigRedFan is offline   Reply With Quote
Old 11-26-2012, 11:15 AM   #2
Rewards Points: 2,516
Yes you can have the switch of the switch-receptacle combo control the under-cabinet lighting.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
BigRedFan (11-26-2012)
Old 11-26-2012, 11:18 AM   #3
Rewards Points: 97
awesome that makes what I am trying to do some much easier and so much better...
anyone have any reccomendations for good led under cab lights
Old 11-26-2012, 11:30 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 382
Kitchen receptacles are prohibited from suppling lighting!
jbfan is online now   Reply With Quote
Old 11-26-2012, 11:51 AM   #5
Are you referring to the small appliance circuits in a kitchen?
Old 11-26-2012, 11:53 AM   #6
jbfan's Avatar
Rewards Points: 382
Yes..
Old 11-26-2012, 12:13 PM   #7
Yes..
Does the oven light count? The small appliance circuit can be used to supply power to a gas stove for clock/timer/ignition source. Typically the stove will have an oven light.
No need to respond to this...Im just bored today.
Old 11-26-2012, 04:11 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,180
If you replace that GFCI receptacle with a non GFCI receptacle/ switch combo you would need to replace the GFCI function. But it is moot because Jbfan said you can not use a SABC for lighting
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 11-26-2012, 09:47 PM   #9
Rewards Points: 81
What if the lighting is the plug-in variety? When I redid the kitchen I put split duplex outlets above the cabinets. One plug has rope lights that sit on top of the cabinets for mood lighting. The other has halogen puck lights that are mounted under the cabinets with the cords running through holes in the bottom and top of the cabinets. They are controlled by a dual switch in a single gang box. I don't recall if it is tapped off of one of the counter circuits or the light circuit.
Reminds me I need to replace the halogen pucks - they run way too hot so I rarely use them.
tev9999 is offline   Reply With Quote
Wiring an outlet to a switch, to a light Athens Electrical 5 01-04-2012 07:03 PM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
