-   -   Changing an outlet to switch (http://www.diychatroom.com/f18/changing-outlet-switch-164764/)
BigRedFan 11-26-2012 11:04 AM
I am interested in doing some undercabinet lighting. I was hoping to have it hard wired so that it would run off a switch.
I currently have a plethora of outlets in my kitchen. I was hoping to replace something like this http://www.lowes.com/pd_245843-334-V...facetInfo=GFCI
with something like this http://www.lowes.com/pd_217938-334-T...tInfo=Standard
and then hardwire the under cabs into the switch portion. WOuld that work??
hammerlane 11-26-2012 11:15 AM
Yes you can have the switch of the switch-receptacle combo control the under-cabinet lighting.
BigRedFan 11-26-2012 11:18 AM
awesome that makes what I am trying to do some much easier and so much better...
anyone have any reccomendations for good led under cab lights
jbfan 11-26-2012 11:30 AM
Kitchen receptacles are prohibited from suppling lighting!
hammerlane 11-26-2012 11:51 AM
Are you referring to the small appliance circuits in a kitchen?
jbfan 11-26-2012 11:53 AM
Yes..
hammerlane 11-26-2012 12:13 PM
Originally Posted by jbfan (Post 1060828)
Yes..
Does the oven light count? The small appliance circuit can be used to supply power to a gas stove for clock/timer/ignition source. Typically the stove will have an oven light.
No need to respond to this...Im just bored today.:laughing:
rjniles 11-26-2012 04:11 PM
If you replace that GFCI receptacle with a non GFCI receptacle/ switch combo you would need to replace the GFCI function. But it is moot because Jbfan said you can not use a SABC for lighting
tev9999 11-26-2012 09:47 PM
What if the lighting is the plug-in variety? When I redid the kitchen I put split duplex outlets above the cabinets. One plug has rope lights that sit on top of the cabinets for mood lighting. The other has halogen puck lights that are mounted under the cabinets with the cords running through holes in the bottom and top of the cabinets. They are controlled by a dual switch in a single gang box. I don't recall if it is tapped off of one of the counter circuits or the light circuit.
Reminds me I need to replace the halogen pucks - they run way too hot so I rarely use them.
