Old 06-15-2011, 10:42 AM   #1
Changing an outdoor plug in an rv
On the outside of the RV there is a receptacle with a cover. The outlet is working but has brown marks. I want to change it. Can I use a regular receptacle such as an indoor one? The GFI plug is located inside the unit. I am getting conflicting answers.
JOHN L. SULANO is offline   Reply With Quote
Old 06-15-2011, 11:00 AM   #2
joed's Avatar
If the receptacle is protected by a GFCI then a regular receptacle will work fine as long as the box has the proper weather cover over it.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
JOHN L. SULANO (06-15-2011)
Old 06-15-2011, 11:05 AM   #3
I would suggest to put a weather resistant recept there. They are marked with WR on the face of the recept. Not a substitute for the weather tight cover - rather additional protection and to make it last over time batter.
____________
Vince
The Following User Says Thank You to vsheetz For This Useful Post:
Old 06-15-2011, 11:07 AM   #4
It has an outdoor cover already.
Old 06-15-2011, 11:07 AM   #5
Thank you
Old 06-15-2011, 11:08 AM   #6
Thanks Joe
Old 06-15-2011, 11:13 AM   #7
The current receptacle does not have WR on it. It looks like a regular indoor one. The cover and seal is intact.
Tags
changing receptacle
changing svc panel, not upgrading amps hilltop Electrical 8 06-13-2011 12:04 AM
Cheap suggestions for changing look of bathroom sink countertop? mrdazzo7 General Discussion 11 01-07-2011 06:43 PM
changing brake pads on a 2001 Mercury sable with ABS deck hand Automotive Repairs 10 02-18-2010 03:57 AM
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 09:59 PM
Need Help Changing an Old Outlet AOP Electrical 6 09-03-2008 07:38 AM
