Old 10-13-2009, 02:28 PM   #1
diy'er
la15ota's Avatar
Changing a Outdoor light to a socket
I would like to put up some outdoor string lights.
I have a outdoor (florescent, snap in bulb) light fixture that connects to a switch inside the house.
I'm curious if I can have that light fixture replace with a outlet plug, so that I can have the string lights connected to it and be able to turn them on and off with the switch inside the house.
I will also check with a local electrician, but I was curious of your guys opinions.
la15ota is offline   Reply With Quote
Old 10-13-2009, 02:37 PM   #2
Xtreme DIY'r
Like the lights in the picture?
What wattage will the lights pull?
Outdoor outlets require an in-use wet cover, which might not look right depending upon the location
There is a screw-in adaptor, but it is only rated for 650w
Old 10-14-2009, 12:24 AM   #3
diy'er
la15ota's Avatar
Yes, similar to the picture but not on such a grand scale, more like 4 or 5 switch backs.
Each socket is rated for up to 25 watts.
I'm looking to have 28 sockets so max of 700 watts, but I'll probably use the 11 or 15 watt bulbs with will reduce to 308 or 420 watts.
The light fixture isn't in a highly visible area and I'd be ok with covering it with the in use wet cover. This is what I'd like to do, but I don't want to violate some code.
I can't use the screw in adapter because these are weird plug in florescent bulbs.
Old 10-14-2009, 01:02 PM   #4
J. V.'s Avatar
Sure, you can install a receptacle where the fixture exists. Your electrician will have you fixed up in no time.
Old 10-14-2009, 02:27 PM   #5
Xtreme DIY'r
Yes you can install an outlet
Just need a box rated for use, GFCI outlet & in-use cover
The light switch will still control the outlet if you wire it right
Old 10-14-2009, 02:49 PM   #6
diy'er
la15ota's Avatar
Great thanks
Thermostatically controlled light socket????? beebiz Electrical 28 11-26-2011 04:45 PM
HALO H7ICAT Socket Plate Adjustment BigJimmy Electrical 3 05-28-2009 02:25 PM
HOw to tell if a socket is propery grounded Jdrewrd Electrical 9 03-21-2009 09:10 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
socket broken andrea Electrical 1 07-05-2005 07:18 AM
