Changing Out Old Cord For Drill - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 04:01 PM   #1
changing out old cord for drill
i have a 110v electric drill with a 2 prong cord and would like to change it to a longer #14 3 wire/3 prong cord. right now it is a 2 prong cord w/o ground. any suggestions on how to ground this?
mcfangz is offline   Reply With Quote
Old 05-01-2011, 04:06 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Is the drill housing plastic? There is probably simply nothing to ground on it, so it's ok to just have 2 prongs. My newish Dewalt only has 2 prongs.
Old 05-01-2011, 04:07 PM   #3
Licensed electrician
Rewards Points: 1,766
Your drill is most likely double insulated and does not need the third wire.
mcfangz (05-01-2011)
Old 05-01-2011, 04:21 PM   #4
Ditto.....Double Insulated tools are equipped with a polarized plug (one blade is wider than the other.)
Gizmoman is offline   Reply With Quote
The Following User Says Thank You to Gizmoman For This Useful Post:
Old 05-01-2011, 07:51 PM   #5
yes , it is a double insulated AEG SBE-38R 115 VAC 4A 50-60 HZ. actually the plugs are both 1/4" in width. some of my other 2 prongs are 1/4" and 3/8" - polarized. these don't appear to be polarized. what should be done with the green/ground wire on the new cord?? thanx.
Old 05-01-2011, 09:26 PM   #6
Rewards Points: 266
You don't need it. Cut it off or cap it. I would use a two wire cord instead.
junkcollector is offline   Reply With Quote
Old 05-02-2011, 10:27 AM   #7
Rewards Points: 204
Cord and plug must be an assembly listed for the tool. You are not supposed to make cords like we all know we do......LOL.
Old 05-02-2011, 10:48 AM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Oops...
Kyle
Is my extension cord OK? MT Stringer Electrical 4 10-20-2009 07:25 AM
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 04:42 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 07:17 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Do I have a 30 amp or 70 amp welder. And help wireing it. Tmb9862 Electrical 17 12-04-2006 09:21 PM
