Changing My Garage Circuit From 15 To 20 Amp - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2014, 09:04 PM   #1
Rewards Points: 86
changing my garage circuit from 15 to 20 amp
Hi all,
I opened all switches/receptacles/junction boxes in my garage and am certain that all wiring is 12-gauge. Is it safe to just change the breaker from 15 to 20 amp along with all the receptacles and switches? Or am I missing something?
petermk is offline   Reply With Quote
Old 11-23-2014, 09:08 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 2,668
Originally Posted by petermk View Post
Hi all,
As long as it is all #12, good to go.
Switches and receptacles do not have to be 20 amp.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 11-23-2014, 09:09 PM   #3
Master Electrician
Rewards Points: 2,472
Hi all,
Yes to the breaker, no need to change switches or receptacles if the switches are duplex.
brric is online now   Reply With Quote
Old 11-23-2014, 09:22 PM   #4
Licensed electrician
Rewards Points: 3,252
Rarely does someone install a breaker smaller than the wiring can support. If it is all #12 you are good.
Old 11-23-2014, 09:59 PM   #5
Rewards Points: 86
The wiring is brand new, while the breaker is old. There are two 3-way switches and one duplex 15 amp GFCI outlet.
Old 11-24-2014, 12:59 PM   #6
Rewards Points: 2,410
Double check the wiring between the 3 way switches and up to the light fixtures. That has to be 12 gauge as well in order for you to up the breaker to 20 amps.
Fifteen amp receptacles are okay on a 20 amp circuit as long as there are at least two receptacles of any description on that circuit -- for example one duplex or two round singles.
(One morning on WRKO Radio) The tub's not clean! Let's remodel the bathroom.
(One afternoon on WRKO Radio) It's time for an oil change. I'm going to trade in the car for next year's model.
Old 11-24-2014, 02:58 PM   #7
Electrician
Rewards Points: 2,828
All explanations spot on. If all the wiring is #12 a 20amp is ok.
Jump-start is online now   Reply With Quote
Old 11-24-2014, 06:56 PM   #8
Rewards Points: 760
All means all. That is every piece of NM cable must be 12AWG or higher. Most, the majority, nearly all, all I could see, I'm thinking its 12AWG, don't do it. You need to be sure
curiousB is offline   Reply With Quote
Adding a circuit to a drywalled garage csm0017 Electrical 19 04-20-2012 12:38 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
new garage circuit lendosky Electrical 4 10-28-2011 08:26 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
