Changing Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 08:29 PM   #1
Question
Changing light switch
I know this would seem easy but my house is no ordinary house. First off, the reason for switching out the light switch to begin with is because it got so hot that it stopped working (the screws were glowing red). I took out our dimmer switch and found 4 sets of wires going into the box...How do I install just a regular switch? Is there some fancy way I should do this?
hobo2103 is offline   Reply With Quote
Old 10-27-2011, 09:12 PM   #2
Electrical Contractor
Glowing red? Sounds like you have bigger problems. Assuming that was an exaggeration just get a switch and wrap the solid wires around each screw clockwise. Don't use the stab-in feature! I can't count how many service calls ended with me finding a bad connection where someone used the stab-in.
Sine is offline   Reply With Quote
Old 10-27-2011, 09:27 PM   #3
Licensed electrician
Rewards Points: 1,872
The most common dimmer is only rated for 600 watts before any derating. How many watts of lighting were in use at the time? Are the bulbs incandescent or fluorescent?
The new switch should be connected the same as the old switch. However only one wire should be under a screw head.
Tags
electrical , lighting circuit , switch
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 12:09 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
Changing Light Fixture - Way too many wires and light wont switch off marapapa Electrical 3 01-13-2006 01:16 PM
