Changing High Pressure Sodium Bulbs Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 02:03 PM   #1
Changing High Pressure Sodium bulbs question
Anyone ever had any kind of problem replacing High-Pressure Sodium bulbs while leaving the power ON ?
I need to replace a bulb but there is no specific breaker or switch to turn the power off and I cannot power off the whole building.
Is it safe to replace HPS bulbs while leaving the power ON ?
rotteux is offline   Reply With Quote
Old 07-14-2011, 02:57 PM   #2
Unplug your ballast.
psyguy is offline   Reply With Quote
Old 07-14-2011, 09:22 PM   #3
Electrical Contractor
kbsparky's Avatar
IF the bulb is still lit, you would need some heavy-duty asbestos-type gloves to prevent from burning your hand. Those bulbs get HOTT while operating!
I would not recommend attempting such a feat without proper protection.
-KB
Old 07-15-2011, 04:45 AM   #4
Like said above, those lights get freaking hot when they're on. If the bulb is shot and it's cool there is absolutely no problem changing it with the fixture powered up. Just like changing a regular light bulb. Don't look right at it when it comes on either....lol
CheapCharlie is offline   Reply With Quote
Old 07-17-2011, 11:26 AM   #5
Rewards Points: 282
this is a bad idea for lots of reasons.....heat as already mentioned, but also when you screw the new bulb in you will be blasted by UV light.
why is there no disconnect/switch for the light? how do you change the capacitor when it goes bad?
jcrack_corn is offline   Reply With Quote
Old 07-17-2011, 11:27 AM   #6
do these lights burn all day long?
Old 07-18-2011, 11:03 AM   #7
Rewards Points: 58
If you cannot turn off the fixture without turning off the main breaker, I would find a way to get a switch installed first. While the power is out, you can change your bulb then.
J. V. is online now   Reply With Quote
Old 07-18-2011, 12:40 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,852
There has to be a breaker for it. If not, then it doesn't have overcurrent protection and that's a very dangerous problem. Perhaps you just don't know which breaker it's on? With that said, I'd just change it hot. HPS lamps don't even produce much light at startup; they have to warm up before they're bright enough to be unpleasant. Just don't stick your fingers in the socket.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
J. V. (07-19-2011)
Old 07-18-2011, 01:40 PM   #9
They may not get bright right away, but they're bright enough at startup to leave you seeing spots. I've changed lots. And depending on how many lights you have on a circuit, a simple switch may not do. You may need a lighting contactor.
Grab a thick glove, change it out. Don't look right at it when it's close to being screwed in all the way. Simple.
Old 07-18-2011, 09:36 PM   #10
I am going to disagree with the responses above. I'm a lighting tech and change hot hps lamps frequently. I use a silicone oven mitt, and have had zero problems. I say go ahead, but keep in mind that those things are wicked hot.
lightinggod is offline   Reply With Quote
Old 07-19-2011, 11:25 AM   #11
Rewards Points: 58
What is a lighting tech. A janitor with a ladder? This is a DIY site. I am going disagree with you as you could get someone hurt. I change ballasts hot all the time. Does that make it right? No.
Old 07-19-2011, 11:09 PM   #12
No, you non reading son of a beachnut, I have been in the lighting industry in service positions for 25 years. Who do you think you are? Nobody was talking about changing ballasts hot, the original comment was about changing lamps without de-energizing the fixture. Where did you learn reading comprehension? Why don't you go play with your wirenuts?
High Oil Pressure reading, knocking engine GeraldR Automotive Repairs 8 08-02-2010 05:56 PM
Pressure Tank Question? cruzplanner Plumbing 3 02-11-2009 12:11 PM
Pressure Washer Question DIYchick Tools 8 02-05-2008 06:44 PM
City water pressure and volume question Jeekinz Plumbing 2 07-31-2007 01:18 PM
Pressure Balanced faucet question scp Plumbing 2 01-07-2007 06:15 PM
