Changing Garage Electrical Panels - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2011, 07:54 PM   #1
changing garage electrical panels
My garage currently has a 50 amp electrcal panal using 6/3 copper wire. I would like to change to a 100 amp electrical panal so I can have three 30 amp breakers and 6-7 breakers of 15-20 amps. My question is can I use the 6/3 copper wire or do I need to change this wire to something else?
RULONY is offline   Reply With Quote
Old 04-07-2011, 07:57 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If you leave a 50 amp breaker feeding the panel and just install a 100 amp panel for the breaker space, you can use the #6. If you want an actual 100 amp feed, you have to change the wire to the proper size.
Old 04-07-2011, 09:30 PM   #3
thanks for the help. one more question
If I want to use a true 100 amp panal what size of wire use I use instead of 6/3 copper?
Old 04-07-2011, 10:16 PM   #4
Scared Electrician
Saturday Cowboy's Avatar
you can use a 100a panel feed from a smaller breaker (say 50a) and save money because 100a panels are cheaper than 50a panel boxes. How ever if you calculate that you need more than the existing 50a supply then the wire will have to be changed. Have you done a service calc?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-08-2011, 08:46 PM   #5
Missouri Bound's Avatar
The distance between your main and sub-panel would have a bearing on which size wire you use. A short run could use #4 wire....longer runs would require a larger wire. Again this depends on whether or not you want a true 100 amp service.
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 10:03 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Garage Electrical Wiring stickwagon Electrical 1 10-16-2010 12:16 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
