Changing Bulb Sockets - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2008, 12:13 AM   #1
dwa
Hi. We're building a new home and have several fans installed with fan lights. The lights have candelabra bulbs with max wattage of 65 watts. I want to change from candelabra base to standard base and increase the wattage to 100 watts. I know I will probably have to change the wiring in the fixture to handle the increased wattage, and obviously the sockets will have to be changed to regular base. I would appreciate any advice as to what gage wire I should use to each socket and any information as to how to determine a sockets maximun wattage. I've looked at Lowes and HD, but the sockets there with porcelain don't seem to have any information on them. Will I have to go to a regular electrical supply store. Appreciate any advice/info. Thanks in advance
dwa is offline   Reply With Quote
Old 03-21-2008, 09:36 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
You are not going to be able to modify the light kit you have. If you want 100 watt bulbs, you must find a light kit that will fit your fan, and allow the use of 100 watt bulbs.
I have seen some that use 100 watt bulbs, but not the standard base.
Good Luck!
Old 03-21-2008, 10:21 AM   #3
Electrician
I think ceiling fans will only now accept candelabra lamps. Its an energy star agreement, so your pretty much stuck.
chris75 is offline   Reply With Quote
Old 03-21-2008, 03:30 PM   #4
dwa
Thanks for the responses. You are right, fan lights now only come with the candelabra bulbs. Unfortunately, I've only seen a max of 65 watts. Maybe that is why they did it. Again, thanks
A faulty bulb or a faulty fixture? don54 Electrical 5 12-25-2007 05:38 PM
Low Voltage Lighting Bulb Life IdahoBob Electrical 2 12-23-2007 01:24 AM
Outside sockets on the same ring? Mark16 Electrical 2 10-13-2007 08:50 PM
new sockets seanie Electrical 1 08-20-2006 07:07 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
