Changing A Breaker. Turn Main Power Off First? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 04:26 PM   #1
Rewards Points: 590
Changing a breaker. Turn main power off first?
Silly question I know, but I saw a You Tube video where they change a breaker and they did not appear to switch off any main breaker of any sort.
They just turn the breaker they are changing off, and then unscrew the wires. It seems like those two wires would surely be HOT after you pull them out of the breaker.
Am I missing something here? Or are we just assuming that one will be careful inserting the hot wires into the new breaker?
noone is offline   Reply With Quote
Old 11-15-2011, 04:30 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now see, this is one of those posts that just makes me shake my head in wonderment. Why on earth would you not turn off the power when it is right there in front of you only inches from the breaker you intend to work on? Maybe I'm jumping the gun and there is a good reason for a novice to want to reach into a hot panel with a metal tool and mess around with the hot wires. If there is a justifiable reason, please let me in on it.
You Tube advice huh?
Old 11-15-2011, 04:33 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Once the breaker has been turned off, the wires on the breaker are no longer hot.
I suggest all diy'ers turn off the main to do anything inside a panel.
Old 11-15-2011, 04:33 PM   #4
Rewards Points: 590
I watched the video twice thinking I maybe missed something.
Nope, he didn't ever turn off the main power. He just tests that the breaker was off, BEFORE he removes the wires from it. Uh, yeah, the breaker will surely be off once you switch it off. You don't need a sniffer to tell you that, you can just go try to turn a light on or something instead...
Or am I missing something here?
Old 11-15-2011, 04:34 PM   #5
Rewards Points: 590
Ok, then I am missing something here. How does turning the breaker off kill the power on the wires running into it?
Old 11-15-2011, 04:35 PM   #6
Military Mom of 4
Snav's Avatar
So: trust a faulty breaker that I'm having to remove to actually cut off the power just because I tell it to?
No - If I'm changing it it's usually because it's not working right.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 11-15-2011, 04:38 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The source of the power comes from a bar in the panel behind the breaker. The wire is the outbound side of the breaker.
You know? On second thought maybe YOU shouldn't be anywhere near an electric panel for any reason.
The Following User Says Thank You to Bud Cline For This Useful Post:
gregzoll (11-15-2011)
Old 11-15-2011, 04:40 PM   #8
Rewards Points: 590
For some reason I deducted that a breaker worked like a switch.
Silly me.
Still, seems like if you hit that bar with a screw driver you could fry yourself with the main power on, right?
Old 11-15-2011, 04:43 PM   #9
jbfan's Avatar
Rewards Points: 478
Silly me.
Yep!
Old 11-15-2011, 04:44 PM   #10
Licensed electrician
Rewards Points: 1,610
Yes it would be possible to receive a shock while working in a panel, even with the main breaker off.
Old 11-15-2011, 04:47 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Think: "Crispy Critter".
Old 11-15-2011, 04:49 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Actually it does.
Old 11-15-2011, 04:52 PM   #13
Rewards Points: 590
Actually it does.
I just didn't realize it was the bar behind it powering it. I thought stupidly that one wire was input, the other was output....... over complicating things.
Old 11-15-2011, 04:55 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Whatever you do...
Don't try to lick that bar with your tongue.
Old 11-15-2011, 05:03 PM   #15
Rewards Points: 590
Whatever you do...
I thought you had to lick the bar right before you insert the new breaker??
Main Breaker Melting rubberhead Off Topic 8 03-16-2011 07:50 PM
Emergency power backup via power inverter upabove Electrical 14 06-08-2010 11:18 PM
Breaker tripped after power outage. What's up? Leah Frances Electrical 14 02-12-2009 06:56 PM
Main Breaker is tripping rdmccaw Electrical 18 02-05-2009 10:27 PM
Main Breaker won't stay on Please Help mikpowl Electrical 8 01-10-2008 09:22 AM
