#1 |
Changing 70W HPS bulbs
Hi all,
I need to replace a 70W high-pressure sodium bulb in a outdoor wallpack unit. The photocell has been bypassed with tape. I just can't find the circuit breaker switch! They aren't labeled properly... Someone told me that I could get a nasty shock cause the unit produces high voltage at startup. Is there any real shock hazard? Thanks |
#2 |
Licensed Electrical Cont.
Ab-so-freakin-loutely there is a risk of shock!
What do you mean you can't find the breaker?? Put a tester on the incoming line and turn off each breaker until you find it.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#3 |
Unfortunately I can't mess with these breakers. Some critical equipment runs.
But thanks for the advice. I won't touch this -or any- live HPS bulb. Last edited by ritch007; 07-18-2012 at 02:31 PM. |
#4 |
Another question... if I turn off the breaker for a 70W HPS wallpack, for how long will there be any residual current in the components (e.g igniter, ballast, capacitor)?
Thanks! |
#5 |
I'm not exactly sure, but in all my years and many hundreds of HID light repair/installs I have never gotten a shock from a de-energized fixture.
#6 |
Master Electrician
judging from what you've said this isn't a light located at home. Regardless of the output voltage at startup there's a good chance that's a 277v light and that's more than enough voltage to do alot of damage right there.. the igniter may toss out around a 2500v pulse on startup to get things moving.
Sarcasm is my friend I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own. |
| Display Modes | |
| Blinking LED light bulbs | northerner | Electrical | 5 | 04-11-2012 01:30 AM |
| F34 T12 vs F40 T12 bulbs | KE2KB | Electrical | 8 | 12-14-2011 07:17 AM |
| Changing High Pressure Sodium bulbs question | rotteux | Electrical | 11 | 07-19-2011 11:09 PM |
| double-ended halogen fixture bulbs stop working | watt-ever-ny | Electrical | 6 | 11-20-2007 06:25 PM |
| Formula for changing lights to recessed bulbs? | Jemo | Electrical | 12 | 01-26-2007 06:02 PM |
