-   -   Changing 70W HPS bulbs (http://www.diychatroom.com/f18/changing-70w-hps-bulbs-150705/)
ritch007 07-18-2012 01:21 PM
Hi all,
I need to replace a 70W high-pressure sodium bulb in a outdoor wallpack unit.
The photocell has been bypassed with tape. I just can't find the circuit breaker switch! They aren't labeled properly...
Someone told me that I could get a nasty shock cause the unit produces high voltage at startup. Is there any real shock hazard?
Speedy Petey 07-18-2012 01:25 PM
Ab-so-freakin-loutely there is a risk of shock!
What do you mean you can't find the breaker?? Put a tester on the incoming line and turn off each breaker until you find it.
ritch007 07-18-2012 01:28 PM
Unfortunately I can't mess with these breakers. Some critical equipment runs.
But thanks for the advice. I won't touch this -or any- live HPS bulb.
ritch007 07-18-2012 01:34 PM
Another question... if I turn off the breaker for a 70W HPS wallpack, for how long will there be any residual current in the components (e.g igniter, ballast, capacitor)?
Thanks!
Speedy Petey 07-18-2012 01:44 PM
I'm not exactly sure, but in all my years and many hundreds of HID light repair/installs I have never gotten a shock from a de-energized fixture.
andrew79 07-18-2012 08:30 PM
judging from what you've said this isn't a light located at home. Regardless of the output voltage at startup there's a good chance that's a 277v light and that's more than enough voltage to do alot of damage right there.. the igniter may toss out around a 2500v pulse on startup to get things moving.
