Changing 250 Volts Into 115 Volts - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 02:58 PM   #1
changing 250 volts into 115 volts
Purchase an air condition that uses 115 volts , old outlet is 250 volts. My husband change the 250v with a 115 volt outlet, but the air condition keeps shutting down.
hottlilmama is offline   Reply With Quote
Old 05-24-2009, 03:36 PM   #2
Licensed electrician
Rewards Points: 1,472
Did he also change the wiring at the breaker panel? There is more to it than just changing the receptacle.
He may still be supplying 240 volts to the AC.
Old 05-24-2009, 03:40 PM   #3
Did he change the wiring feeding the outlet to 120?
He, or an electrician, needs to do that from within the panel.
If not, that's going to be an issue...
thegonagle is offline   Reply With Quote
Old 05-24-2009, 04:58 PM   #4
Rewards Points: 874
I would hope that your husband knows enough that changing the receptacle alone won't change the voltage. If not, then he has no business doing the job, and should call a qualified electrician.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 05-24-2009, 05:47 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Ding ding ding ding! We have a winner!
Old 05-24-2009, 05:49 PM   #6
Considering it's been 3 hours, I highly doubt she will be back to admit this was actually the case.
Old 05-24-2009, 05:57 PM   #7
" Euro " electrician
frenchelectrican's Avatar
I am pretty sure some of the new A/C windowshakers do have low / hi voltage protection in the electronic contol board and if sense too high a voltage it will shut it down.
I agree with one poster that is the best answer for a while.
Merci,Marc
Old 05-25-2009, 08:57 AM   #8
I'm baaaaack to admit that was the case. Husband did not change the wiring in the breaker box. Will call electrician.
Old 05-25-2009, 09:17 AM   #9
Rewards Points: 874
Good choice, and make sure your husband doesn't try any other electrical work without first educating himself. There are lots of good books for DIY electrical.
FW
Old 05-25-2009, 09:33 AM   #10
Sound advice!
Next time it might not be just an air conditioner that dies.
Changing ignition modules Mr Fix It HVAC 1 03-14-2009 05:31 PM
147 volts? gusco1 Electrical 15 11-13-2008 10:44 AM
Does Home AC ever read 0 volts? step.gary Electrical 3 07-01-2006 03:57 PM
103 volts at switch? hawk1996 Electrical 1 06-01-2005 06:16 AM
