Old 08-02-2012, 05:09 PM   #1
changing a 240-277v strip light to a 120v
Ok so here's the deal. I got a really good deal on some shop lights but they will not run on 120 v. only 240-277v ... If i change the ballast on the lights to a 120v will the lights still work?
lilcricket350 is offline   Reply With Quote
Old 08-02-2012, 05:17 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Yes they will, but I hope you got a REALLY good deal, because you'll be into $20+ more for EACH one now.
The Following User Says Thank You to Speedy Petey For This Useful Post:
lilcricket350 (08-02-2012)
Old 08-02-2012, 05:28 PM   #3
Well i got them for $15.00 bucks so im guessing $35.00 is way better than $65. Saved 30 per light. Oh and one more Q... does it matter what kind of ballast i go with? They have advance ballasts in them 240-277v so if i buy a 120v "advance" brand then i should be ok?
Old 08-02-2012, 05:35 PM   #4
E2 Electrician
stickboy1375's Avatar
I personally like the 7 dollar throw away shop lights at home depot... they last just about as long as the lamp, so I just buy complete new setups every so often...
stickboy1375 is online now   Reply With Quote
Old 08-02-2012, 08:10 PM   #5
If there's a panel near by why not just add a double pole breaker and wire them 220?
Old 08-02-2012, 09:10 PM   #6
ANY ballast will work in the right configuration.
Keep in mind, they were probably T12 ballasts and now pretty much all you can get is T8 Electronic ballasts.
Old 08-02-2012, 10:21 PM   #7
You may save $30 per light, but how much time will you spend getting the ballasts and changing them? Time is money.
You can get 4' dual fluorescent fixtures at Home Depot for $20 plus $6 for the 2 lamps. That's under $30 in total when tax is added, and they are ready to go up without any fuss.
I've installed these fixtures often for a long time and I've never been called back to change a ballast.
Calc is offline   Reply With Quote
Old 08-02-2012, 10:29 PM   #8
Master Electrician
i would guess that they were designed to run on 277v three phase, which is 277v hot leg and neutral.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-03-2012, 07:40 PM   #9
If you have a lot of these, look for a box of ballasts on ebay.
ionized is offline   Reply With Quote
Old 08-03-2012, 09:42 PM   #10
Missouri Bound's Avatar
What sockets are on these fixtures, slimline or HO?
Do you want it your way or the right way?
new light to existing switched light sirsparksalot Electrical 4 04-22-2011 04:23 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
changing a light switch switch configuration chriscathedral Electrical 7 07-20-2008 07:54 AM
Changing Light Fixture - Way too many wires and light wont switch off marapapa Electrical 3 01-13-2006 02:16 PM
