Changing From 220v To 110v - Electrical - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 06:15 AM   #1
changing from 220v to 110v
hello, i have an expensive geman vaccum cleaner that we bought her in germany. we are scheduled to leave back to the states and the same vaccum cleaner in the states cost about $1,000. i would like to chnage the wiring from 220v to 110v. i know that i can use a converter, but that would be a hassle everytime we use it.
can anyone help me
thank you
g1latnlovr is offline   Reply With Quote
Old 06-11-2010, 10:56 AM   #2
You're issue is not only voltage, but the 50/60Hz frequency conversion. I doubt your vacuum is rated for 60Hz.
behrend is offline   Reply With Quote
The Following User Says Thank You to behrend For This Useful Post:
g1latnlovr (06-12-2010)
Old 06-11-2010, 11:04 AM   #3
hello, my vacum cleaner states
220v 50/60 hz
1900-2200wts
Old 06-11-2010, 11:32 AM   #4
Rewards Points: 82
220v 50/60 hz
1900-2200wts
Thats not good. The motor is wound or interconnected for 220 volts. You could install a couple 220 receptacles to match the plug on the vacuum, but that would be a good bit of work.
I would take the vacuum once you get here to the states and have a motor shop quote you on a voltage change. They may not need to rewind it. See if this is economical to do. I doubt this is the best idea, but an idea none the less. Otherwise, I would sell it while you are in Germany and buy a new one when you get here in the US. Thats what I would do. Sell it before you move.
Google "European/US adapters" and see if anyone is offering a solution at a good price.
Old 06-11-2010, 11:39 AM   #5
thank you, i will look into the european adapters for now. i have until next thursday to decide what i will do.
can i change the actual 220 wires that go to a ordinary table lamp to 110?
Old 06-11-2010, 05:50 PM   #6
Someone a lot smarter than me will chime in, but US 220 uses two 110 legs and no neutral ....i THINK in Europe it's 220 on one leg and a neutral.
RoyalAcresRod is offline   Reply With Quote
Old 06-11-2010, 07:40 PM   #7
Voltage adapters for Euro appliances
Most of those adapters that are suitable for a motor/transformer are for very low wattage only and very hard to find. Because our tourists are looking to drop the voltage not raise it, best to sell it there.
DaleBelcher2 is offline   Reply With Quote
Old 06-11-2010, 09:24 PM   #8
Rewards Points: 1,452
Do you have 220 volt service in your home? (95% of homes in the U.S. do).
I would go the route of installing a few 220 volt receptacles, perhaps one on each floor in the hallway. Also make and use an extension cord.
Generally 50 Hz appliances that do not contain clocks or timers will work OK on 60 Hz but not vice versa.
A plain transformer of adequate wattage would also work but would probably be quite expensive.
Old 06-11-2010, 09:33 PM   #9
It is a no-brainer to change a 220 volt incandescent light fixture to 110 volts. Simply change the plug and the light bulb.
Other kinds of fixtures (fluorescent etc.) are more complicated. The fixture innards (ballast etc.) must allow reconfiguration or rewiring for 110 volts.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 06-11-2010, 10:38 PM   #10
2200w @ 110v would be 20A. Do you have 20A breakers in your house?
Old 06-12-2010, 03:28 AM   #11
" Euro " electrician
frenchelectrican's Avatar
The other item you will run into is the type of 240 volt North Americian Receptales { Sockets } they are different than what we used in Europe side.
You may end up change the plug itself to work on 240 volts however if your vaccum cleaner is double insulated that is not a issue but if have ground wire a quick tip is get a ohmmeter and read the netural conductor to the vacumm cleaner frame to make sure they are not bonded if that the case you will have to isolated the netural conductor or make a new connection with grounding conductor.
I will remind you the North Americian colour format.{ I will list the hardwired first then corded verison next }
Hardwired { standard building cable or conductors }
Line 1 - Black
Line 2 - Red
Netural - White
Earth - Green { Ground }
Cord
three conductor verison will have little diffrent than hardwire verison is
Black
White { you will have to remark this if you are going to use on 240 volt circuit}
Green
If your cord do have earth pin then it will be fine with that part.
Merci, Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 06-12-2010, 03:37 AM   #12
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
we have 120 vac in the US, not 110. that would make it 18.3 amps. For limited use, a 20 amp breaker should hold.
Old 06-12-2010, 03:43 AM   #13
Yoyizit reread the OP statement again they are sheduled to go back to USA soon so they did not get the house yet but they are asking a advanced question to prepared for it.
Second thing Yoyizit grab your favour DVM and read the 120 volt circuit and report back to either Moi or Nap otherwise I will put up the Conneries meter back up.
Merci,Marc
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 11:46 PM
Adding 110V outlets to 220V line MarcG Electrical 25 04-29-2009 07:04 AM
Convert 220V to 110V wrldruler Electrical 13 09-15-2008 12:55 PM
110v vs. 220v gunboatbay Electrical 17 05-15-2008 09:09 AM
220v from 110v leboyd Electrical 6 03-19-2006 09:51 PM
