Changing To 200 Amp Service, Underground. Need Guidance Please! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 01:40 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by rferoni View Post
They are fused. My service goes from meter to a 60 amp fused pullout to main panel. Info is in original post. As for your question no the meter is a good 15' away.
Ron
But you posted this,
If allowed I think all I'll then have to do is run a separate ground from the new 200 amp panel to the sub-panel and isolate all grounds and neutrals in the sub panel.
Thanks again,
Ron
So im confused... Why would you have to run a separate ground? It should have already been run from the 60 amp disconnect.
Old 04-14-2013, 01:56 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
My guess is that the feeders are in EMT or Rigid.
Old 04-14-2013, 01:58 PM   #18
E2 Electrician
Possibly... You never see that in my area, you have a better chance of seeing SEU run from the disconnect to the panel...
Old 04-14-2013, 02:04 PM   #19
Rewards Points: 55
Ah. I see now what you are saying. Current set-up has only two conductors and neutral going to main panel from meter. We just bought house so not sure how long ago all this was done or who did the work. Didn't 4 wires(two hots, neutral and ground) to a sub panel just become code in 2008'? I know the house was built late 50's.
PS..There is no conduit. The feeders from disconnect to panel is a multi-conductor wire as stated above.
Ron
rferoni is offline   Reply With Quote
Old 04-14-2013, 02:06 PM   #20
E2 Electrician
Ron
Um, no... you were always only allowed to bond the neutral once, and it had to take place at the first disconnect.
Old 04-14-2013, 02:40 PM   #21
Rewards Points: 55
So I just looked at what is going on in my setup. Service goes into 60 amp disconnect and a 6-3 wire leaves 60 amp disconnect and goes to main panel. One black goes to one side of bus bar, red to other, white to neutral bar. I do see a big ground wire(not sure size)to the ground bar but do not know where it comes from. I know the grounds in this house(to all fixtures) were run seperately as all the wiring is two wire only, no ground. Does that tell you anything?
Ron
Old 04-14-2013, 03:03 PM   #22
E2 Electrician
Ron
The ground you speak of sounds like a GEC, which should have landed at the disconnect... take a picture if you want. Best way since it ends all the guess work.
Old 04-14-2013, 03:55 PM   #23
Originally Posted by bcgfdc3 View Post
Is that Current Carrying conductors? Does that include the nuetral?
For your application, yes.
ren79eg is offline   Reply With Quote
Old 04-14-2013, 05:31 PM   #24
Rewards Points: 55
I wasn't sure what GEC meant so I looked it up. Grounding electrode conductor. The ground to the grounding rod. There are no grounding rods in this house. However it looks like the ground wire that I wasn't sure about in the main panel goes to the incoming side of the water meter.
Can't get pics to trun out right.
Ron
overhead service to underground smichaelp Electrical 16 04-10-2012 12:02 PM
Moving electric service entrance to detached garage WillK Electrical 7 10-05-2011 10:13 PM
Relocating Service Drop/Weatherhead Pittsville Electrical 8 08-19-2011 06:52 PM
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
