Old 08-27-2009, 01:31 PM   #31
Xtreme DIY'r
Changing 2 Prong To 3 Prong Outlet
HD does have the pigtails, just check the electric aisle
I usually just use scrap wire that I have hanging around
Old 08-27-2009, 07:03 PM   #32
Originally Posted by Stubbie View Post
J.V.
You cannot just install a 3 prong grounding type receptacle in a metal box or any box for that matter that does not have a proven equipment ground wire back to the grounded conductor at the main panel. The installation as you explained is a code violation unless a proper equipment ground exists. It would serve no purpose to ground a three prong outlet to a metal box if the equipment ground isn't present in the branch circuit. Maybe I misunderstood what you are saying.
Acceptable means if a ground is not present in the box and you do not desire an equipment ground to facilitate the connection of electronics like computers or the added safety that a grounding wire provides.
If the enclosure doesn't have a grounding means — for example, if the box contains old 2-wire NM cable without a ground — you can use a nongrounding type receptacle (Fig. 1). You have two other options as well. You can use a GFCI receptacle if you make sure it's marked “No Equipment Ground,” or you can use a grounding-type receptacle if it's GFCI-protected and marked “GFCI Protected” and “No Equipment Ground.”
If you desire a ground you can run a new circuit or Article 250.130 allows the following
I did it several years ago when my daughter purchased a house, well guess what?? when she sold it it failed electrical every one had to be removed and the two wire outlets reinstalled. Of course we had to by new ones. Oh well live and learn.
SULTINI is offline   Reply With Quote
Old 08-27-2009, 09:43 PM   #33
Here in Ontario Canada, I was required to install Uground recepts in a house with knob and tube wiring!
I ran green/stranded #14 back to a water pipe ground, at the behest of the electrical inspector.
This was rental property and a law was brought in stating that rental properties were to be provided with U grounds.
This was before GFCI recepts became available!
Old 09-01-2009, 12:41 PM   #34
Just wanted to say thanks to everyone who has helped me out on this thread - Replacing the outlets is going slow but going....
Quick question - I came to one outlet last night that for some reason had two black and two white wires both connected to the outlet... I wasn't sure why this was, and verified that no wall switch controlled the outlet that I could find anyway.... so I tried hooking it up with just the one hot black and one ground white wire and no dice. Only once I hooked it up as it was 2B 2W did the outlet work.
tb582 is offline   Reply With Quote
Old 09-01-2009, 01:11 PM   #35
Power comes to that outlet box and daisy chains from there to another outlet box. The first time you reconnected it with one black and one white you connected the downstream part of the circuit leaving the power feed unconnected.
Don't forget to tell the newbies that ground pigtails must be bare or green, neutral pigtails must be white, and hot pigtails must be some other color (black and red being most common).
... (picture, q.v. pp 1) ...
Did I see in the picture a ground wire for the previously ungrounded receptacle brought out to the surface and run exposed along baseboards and up and around doorways and down to the panel more or less following the route of that receptacle's wiring inside the wall? In another thread (or was it some other forum) I commented about this method to avoid fishing or cutting open the wall and a comment in reply said that I was improper.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 09-01-2009, 02:25 PM   #36
Hey who you callin a newbie but seriously thought I did figure that the neutral wire had to be green.
Old 12-04-2011, 03:52 PM   #37
You guys are confusing me with your responses to this question. Here's what I need clarified. I have a Two Wire Outlet in a Metal Box that has BX to a Junction Box in my Basement that is connected to the Panel of Course. Also connected to the Junction Box is another Grounded Outlet or Three Prong connected with Three Wire Romex. I want to change the Two Wire outlet with the BX to accommodate a Grounded Outlet and as I see it ALL I need to do is just snip a piece of copper ground wire and connect it to a screw in the metal box and from there to the Ground screw on the new Outlet and the other two wires, Hot to the Brass Screw, White Ground to the Silver and it's a Done Deal. Am I right or wrong? The other question I would ask is that I have this older cloth or whatever it is covered wire running from this Junction Box to the Panel. If indeed that does have a Copper ground is it OK to keep that or should I just go ahead and replace that with new Three Wife Romex?
srusten is offline   Reply With Quote
Old 12-04-2011, 04:23 PM   #38
Electrician
This post is two years old you should start a new post, you will will get more responses.
darren is offline   Reply With Quote
Old 12-02-2012, 07:32 AM   #39
Dominick Moresco
Great read!
dominick moresco
madmaxx25 is offline   Reply With Quote
Questions About Changing GFCI receptacle to a normal three pronged outlet LYTTONJ Electrical 11 05-04-2011 03:23 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
