Changing 2 Prong To 3 Prong Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 11:31 AM   #16
Rewards Points: 160
This thread must be over a year old. I should have not told the OP to do, what I would have done in my house.
Old 08-17-2009, 12:06 PM   #17
Rewards Points: 174
Originally Posted by mpoulton View Post
Turn off the breaker for that circuit. Check for continuity between the neutral wire in the box and the metal box itself. You should read essentially no resistance (same reading as with your test leads shorted together). If that is the case, then look to confirm what the grounding path is: Is the box installed with metal conduit? Is it fed with metal-sheathed cable? Is there a grounding wire connected to the box? Any of those things would be fine. If you can't tell how it's grounded, don't trust it and install a GFCI instead.
Forgive me but what type of meter should I be using to test this?
and as far as i can tell there is a screw that is located in the back of the box towards the top, and I can see a metal wire attached to it. I would still like to have a way to verify that its grounded properly
tb582 is offline   Reply With Quote
Old 08-17-2009, 03:53 PM   #18
Semi-Pro Electro-Geek
Rewards Points: 2,938
A resistance/continuity/ohm meter. Almost all multimeters do this.
mpoulton is offline   Reply With Quote
Old 08-17-2009, 07:02 PM   #19
tb582 has turned it into his thread
Is there a way to check and see if the metal box is grounded properly, so I can bypass all this and just install regular 3prong oulets?
It's electrical 101 but you need an understanding of how electricity flows thru a simple circuit.
With a voltage tester, check hot to neutral (black to white) and you will have 120 volts. Then check hot to the metal box. If you have 120v, you have some kind of a ground. If you have metal jacketed cable, it may or may not be an approved ground. If you have old non metallic jacketed cable you will see the bare ground wires in the box (99% of the time)
I missed this. Take a pic to be sure but it sounds like you have a ground wire in there. For a short period in the late 50's/early 60's, they started using grounded cable and ground the box but still use 2 prong receps.
220/221 is offline   Reply With Quote
Old 08-18-2009, 11:40 AM   #20
Rewards Points: 174
I took pics this morning but forgot the memory card on my desk - I'll post pics later on. Hopefully we can solve this
Old 08-18-2009, 06:12 PM   #21
Rewards Points: 174
Pics attached, hopefully I can just install std. 3prong outlets
Old 08-18-2009, 07:00 PM   #22
You do have grounded cable.
Test from hot to ground to make sure the ground is complete.
Turn off power. Test to make sure it's off.
1. Remove the screws and clamps from the box. Removing the clamps will make more room. It's a technical violation but the cable is not going to magically get pulled out of the box at this point.
2. Install a ground screw (or the existing screw) in one hole and wrap the ground wire around it clockwise to effectively ground the box.
3. Install a short (appx 5") bare or green pigtail with a ground screw (or existing screw) in the other hole using the same method.
4. Install your new recep using the screw terminals rather than the back stabs amd making sure that the bare wire doesn't end up touching the side screw terminals.
Old 08-18-2009, 07:45 PM   #23
Rewards Points: 174
Great I'm going to try to either find my voltmeter or pick one up tomorrow. I'm assuming it will say in the directions for the meter, but does the red prob touch to the HOT wire and the black prob to the screw in the back to test for ground?
Old 08-18-2009, 09:28 PM   #24
Doesn't matter.
Old 08-24-2009, 08:39 AM   #25
Rewards Points: 174
OK tonight is the night I shall verify if the boxes are grounded, this is the meter I have: http://www.homedepot.com/Electrical-...atalogId=10053
However the directions are less than helpful. What should I have the dial set to?
The I simply just touch one end to the hot wire and the other to the screw in the back, correct? and all this while the electricity is still on
Old 08-24-2009, 02:52 PM   #26
Set meter to "AC volts"
One lead on black, one lead on white will read appx 120 volts.
One lead on black, one lead on ground (or anywhere on the metal box) should read appx 120 volts.
White to ground should read appx zero volts.
Old 08-25-2009, 03:20 PM   #27
Rewards Points: 174
So I'm going on the left side of the meter what do I set the dial to 200? the little audio tone?
Old 08-25-2009, 07:24 PM   #28
Rewards Points: 174
YUP thats exactly what they read!
Can you shed a bit more light on this?
4. Install your new recep using the screw terminals rather than the back stabs amd making sure that the bare wire doesn't end up touching the side screw terminals. .
I'm going to remove the old outlet - Use my new outlet and connect both the white and black wires to the same connectors as they are on in the current setup. I then need to run a small piece of wire from the new outlet's ground screw (which is on the lower side of the outlet) to the grounding screw in the back, correct?
Where do I get this "bare or green pigtail wire? Can you link to it on homedepot's website?
Old 08-27-2009, 09:13 AM   #29
Rewards Points: 174
Anyone?
Old 08-27-2009, 09:25 AM   #30
Learning by Doing
Leah Frances's Avatar
Anyone?
You don't need someone to post a link to HD for you. Maybe you're thinking too hard about this...
The quickest thing, if you have some same gauge wire around, is to strip a convenient length bare.
At HD (or where ever) you can buy pre-cut lengths of green ground wire, or you can buy off the spool in whatever length you need.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Questions About Changing GFCI receptacle to a normal three pronged outlet LYTTONJ Electrical 11 05-04-2011 02:23 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Adding garage outlet Shane Electrical 1 02-23-2006 04:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
