Changed Receptacles In Bedroom, Now No Power - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 04:43 PM   #1
Changed receptacles in bedroom, now no power
I changed the recepticles in the bedroom, after I turned the power back on there was no power. Double checked all the wiring. Everything is fine. Tested the continuity on the breaker. There is power coming out of the breaker switch but none upstairs. I have tested for power at all wires in the bedroom and have no power anywhere (in the bedroom). What should I do next?
Mrjman is offline   Reply With Quote
Old 09-14-2012, 05:28 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,514
1- Moving the wires around has caused a broken wire or loose connecttion.
2 - Something wired wrong.
3 - You have shorted something and blown a breaker or gfci.
Have you removed all wires from the new recepticules and tested them !
Please post results, and tell us how many wires and what colors !
dmxtothemax is online now   Reply With Quote
Old 09-14-2012, 05:41 PM   #3
Post
I removed all the wires and tested each one.
No power detected
All the wires are black and white.
I double checked everything and it's all wired as it should be black on brass and white on silver
I even moved the wire from the breaker to another one and still no result
The last thing I did in a moment of desperation was to hook the old recepticles back up. Still no luck
There is 1 GFCI on this circuit and it was not blown. It is also at the end of the circuit and wired to protect only itself.
I took these steps when I tested the breaker:
Turned off power, removed breaker from bus
Checked for continuity by placing common lead (black) where breaker attaches to bus and hot(red) to screw where black wire leaves breaker.
When I pushed the breaker off there was nothing. When I pushed it on I got tone. My thoughts are a broken wire leading into bedroom or I tested the breaker wrong and it is bad.
Old 09-14-2012, 06:17 PM   #4
Pure Genius
Rewards Points: 150
Is there by chance a switch in the bedroom that controls receptacles?
Dierte is offline   Reply With Quote
Old 09-14-2012, 06:21 PM   #5
Yes switch controls 2 of 4 recepticles. Switch is on and tested for continuity
Old 09-14-2012, 06:35 PM   #6
Is there any power at these switchs ?
Test for power at the breaker also !
Are you 100% sure you have the correct breaker ?
Old 09-14-2012, 06:37 PM   #7
No the whole circuit is out
Old 09-14-2012, 06:39 PM   #8
Yes I'm absolutely positive I have the right breaker. It's the only one that was off while I was replacing the recepticles
Old 09-14-2012, 09:19 PM   #9
Pure Genius
Rewards Points: 150
What are you using to test power
Old 09-14-2012, 09:55 PM   #10
First test your tester !
Use a known good source.
If its ok, test the load side of the relevent breaker,
If theres power there, but not at the outlet or switch,
Then its obvious that you have a broken wire or joint.
Just moving around old wires can sometimes break them,
they can become brittle if they havent moved in a long time.
The Following User Says Thank You to dmxtothemax For This Useful Post:
Mrjman (09-14-2012)
Old 09-15-2012, 08:28 AM   #11
Smile
I just bought the tester yesterday. I did, however test it on a working socket and got the expected result. Thanks for your help. I'm going to change out the breaker just to make sure that's not the problem. If I still have no power in the bedroom then I'm going to have to call an electrician becaus tracing a break and running new wire is a little beyond my realm of expertise and equipment budget.
Old 09-15-2012, 08:31 AM   #12
Resi EC
Rewards Points: 252
duplicate
Gac66610 is offline   Reply With Quote
Old 09-15-2012, 08:32 AM   #13
Resi EC
Rewards Points: 252
Does the circuit have a ground/bare wire?
Old 09-15-2012, 11:28 AM   #14
Unhappy
Update
I went back today to do a little more investigation. I found there are more recepticles in front of the room without power. So far I have found no loose wires in the ones up front. I'm still not sure which recepticle leads into the room without power. Me thinks it's time to call in a professional. Thank you all for helping me troubleshoot.
Old 09-15-2012, 11:46 AM   #15
Missouri Bound's Avatar
Cable or conduit in your home? You most likely pulled a neutral loose when you took out a receptacle, or didn't re-connect it. Do you have power to ground and what type of tester are you using?
Do you want it your way or the right way?
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 02:30 PM
No Power in bedroom FoxyRoxy Electrical 3 09-26-2011 04:54 AM
Dishwasher Power Supply Captain.Sassy Electrical 14 09-14-2011 05:28 AM
No power to outlets and ceiling fans in living room and Master bedroom? boneglove Electrical 12 03-27-2011 07:32 PM
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
