So i was changing out all of my almond colored outlets and switches for white because we have repainted. When I got done changing 4 outlets and 4 switches, the outlets are now all always on and the 2 switches that controlled the bottom outlets now do nothing.
There are 4 sets of plugs around the room, the bottom outlets have always been on a switch. There's a single 3-way switch on one side of the room for them then there's another 3-way switch on the other side of the room that is also for the outlets but that is also next to two other switches, one 3-way and one not.
The order of them are as follows:
3-way Outlets | 3-way Light at top of stairs | Outside front door light.
It seemed to me that I could potentially reversed something when I replaced both of those three ways but I don't think I did. I did each switch one at a time so as to not cross wires around.
Can anyone tell me if it's likely a switch or an outlet that might be causing it?
Thanks!
Thanks!
