Changed Outlets, Half Don't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2009, 11:13 PM   #1
Question
Changed outlets, half don't work
1st post!!! Long time forum user (usually auto), but first time on an home improvement one. Just bought my first house so I look forward to a long relationship with you all.
I attempted one of my many projects I have planned this past weekend...changing the ugly ivory outlets to white outlets. I'm pretty sure I wired it all corrrectly as it wasn't rocket science. After I was done only some of them work, and some, one-outlet doesn't work on the 2-outlet panel.
I tried reseting the breaker through the main switch and no luck. I tried turning off each one individually and back on and no luck.
Can anyone help and point to what I did?
P.s. wierd thing is, the oven doesn't have power and I didn't change the one behind it. weird
Any help is appreciated more than you know.
-Jason
nighthawk87 is offline   Reply With Quote
Old 06-30-2009, 11:21 PM   #2
How many outlets did you replace?
Are outlets that were NOT replaced not working?
-Jason
Were the outlets working before you swapped them?
Was this house at some point, before purchase for a while?
Are you sure the breakers went all the way on?
Try shutting them off all the way, then on
If the Stove isn't working it sounds like one hot from the panel is dead
Old 06-30-2009, 11:24 PM   #3
Your main breaker didn't reset. Half the circuits will be dead. I bet when you turn the oven on, all receps will "work".
Turn it off and on again...a couple times.
220/221 is offline   Reply With Quote
Old 06-30-2009, 11:40 PM   #4
I replaced about 3 in the kitchen, 6 in the living room, 1 in the bathroom, 3 in the bedroom, 3 in the other bedroom, 1 in the master bathroom. Some work, some don't, and some "half-work" with only one outlet on the panel working.
All breakers are facing the same direction and power is on to the house. I tried already shutting off each individiually and turning back on. That didn't work.
How can I turn the oven on if it doesn't have power? Please clarify further.
Thanks for suggestions so far, keep 'em coming. I'd be so happy if I can solve this and eat dinner tonight
Old 06-30-2009, 11:51 PM   #5
If you have a range or oven with knob controls, turn them to the on position and check the receps.
If you turned off the main, (you didn't verify that) I am 90% certain that it didn't reset.
It happens.
Bad news is, sometimes it WON'T reset and you will have to replace it.
Old 06-30-2009, 11:55 PM   #6
It happens.
The oven is operated by buttons on the top, it is a new GE oven. Normally the clock would be there but its not.
I have turned off the main power to the house a bunch of times on and off. I have turned off each individual switch off and on once. Still no power.
Old 07-01-2009, 12:20 AM   #7
Any other 240v stuff?
Dryer, AC, water heater?
See if the dryer works. Make sure it gets hot (the motor is 120V)
Is there only one main breaker? Is it inside or outside? If inside, check outside too. Main fuses anywhere???
Old 07-01-2009, 12:22 AM   #8
I think I only have the one outside.
Old 07-01-2009, 12:25 AM   #9
I have power to both washer and dryer, which are in the garage. I walk from garage into kitchen where half of the outlets don't work.
-Fridge works
-Microwave above oven works
-Garbage disposal works
-dishwasher works.
I'm so confused.....
Old 07-01-2009, 12:34 AM   #10
You need a voltage tester.
Are you 100% sure the dryer gets hot?
Old 07-01-2009, 12:49 AM   #11
Well, my stuff works so I am going to bed
Old 07-01-2009, 09:01 AM   #12
When you shut off the breakers, you have to actually pull it towards the off position in some cases. Then it will "cacth" & turn it back on
Was this house empty at some point, before purchase for a while?
What do you mean 1/2 work in the panel?
Some of what only half work in the breaker panel?
Old 07-01-2009, 05:15 PM   #13
Journeyman Wireman
I'm guessing they are wired throught the recept? Wire on each screw. Sounds to me like you might have some bad connections or bad recepts.
Did you turn off the stove by accident and the breaker won't reset or is bad?
jbberns is offline   Reply With Quote
Old 07-01-2009, 05:18 PM   #14
Journeyman Wireman
Does the old wire have a ground? If not and you put in grounding receptacles you have to have gfci protection or run a ground to each outlet. But has nothing to do with why it's not working
Old 07-02-2009, 12:23 PM   #15
Rey
Jason... if you have a GFCI receptacles anywhere in the house.. try to reset them all...there is a chance that some of your outlets are connected to to these GFCI receptacles or outlets... specially in the bathrooms, kitchen and basements...
Hope this will solve your problem.
Rey is offline   Reply With Quote
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Ranting about attic work IvoryRing Electrical 6 04-16-2008 08:21 AM
Question about wiring outlets together firemanpato Electrical 5 01-05-2008 04:52 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
