Changed Electrical Switch Now Powe To Whole Whouse Is Off - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 02:27 PM   #1
Changed electrical switch now powe to whole whouse is off
I changed an electrical switch thinking it was bad. I changed it and wired it the same way it was before turned the power on and turned it on nothing. I changed it back to the old one and wired it up the same now the power in the whole house turned off. What happened?!?
mossyoak87 is offline   Reply With Quote
Old 11-09-2012, 04:06 PM   #2
...this could be a very dangerous situation...what is your level of experience?
Bobka is offline   Reply With Quote
Old 11-09-2012, 04:20 PM   #3
..OK if you are comfortable working with electricity....turn off all the breakers....make a note not to turn on the breaker that opened originaly...now turn main back on... and slowly turn on other breakers 1 at a time....Afirst guess is you shorted a ground or neutral to line...take apart the switch you installed and either call a pro or someone that can trace this out good luck be careful,,
Old 11-09-2012, 04:29 PM   #4
Ok I'll try when I get home. What happens when I turn them off and turn them a back on and nothing happens. Also I took out the new switch and have the old one in. Should I take the original switch out and put the new one in or what. I'm a novice at electricity
Old 11-09-2012, 04:50 PM   #5
ok...you should get someone who has some experience there....again I think you created a short circuit at the switch ....not all things at switches are as they appear....white condutors could be switch legs for example...saftey first ok? good luck be careful...
The Following User Says Thank You to Bobka For This Useful Post:
user1007 (11-10-2012)
Old 11-09-2012, 05:19 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,104
Can you post a picture of the wires,
and a picture of the new switch ?
dmxtothemax is offline   Reply With Quote
Old 11-09-2012, 06:52 PM   #7
Rewards Points: 6,652
If you are flipping off and on the main breaker and no power, call your power company to have them check the meter base, and the power going into the main panel if they can't find a problem outside. Worst case scenario, they will pull the meter until things are fixed.
Now of course, if you caused a dead short and damaged the main breaker, or one of the meter lugs, you will have to pony up and call an electrician.
Old 11-09-2012, 07:32 PM   #8
Pure Genius
Rewards Points: 150
Do you by chance have a disconnect outside?
Dierte is offline   Reply With Quote
Old 11-10-2012, 09:47 AM   #9
Too Short? Cut it Again!
This is the key comment in this thread so far. I think we walk on water with hot and neutral wires in opposing hands counseling on this in diy fashion from afar? I am guessing the OP has no testers. I fear he could get hurt.
Call a sparky. Be safe. The nature of the problem seems isolated so the visit should not be too outrageously expensive. I know this is a diy site but sometimes the best advice is to get pro help.
The Following User Says Thank You to user1007 For This Useful Post:
Dave632 (11-10-2012)
Old 11-10-2012, 12:34 PM   #10
Well don't know what happened but came home as the power was back on without doing anything. I have no idea what happened or why it shut off and the. Turned back on
Old 11-10-2012, 02:02 PM   #11
Power outage in your area, or the bill got paid.
Old 11-10-2012, 03:41 PM   #12
Bill was all paid up and there was nothing I have electric gates and they opened up
Old 11-10-2012, 04:08 PM   #13
An old Tradesmen
Rewards Points: 6,548
Moved to Electrical forum.
Old 11-10-2012, 07:26 PM   #14
Rewards Points: 1,192
Freak power outage?
bobelectric is offline   Reply With Quote
Old 11-10-2012, 07:55 PM   #15
Rewards Points: 506
Your question can't be answered with only the provided info.
jlmran is offline   Reply With Quote
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 11:04 PM
electrical key switch Freemanate Electrical 2 11-19-2010 11:54 PM
Electrical switch 3 wires eganrut Electrical 1 11-04-2010 09:09 PM
I changed out a switch and am now having issues... amygirl2727 Electrical 12 11-23-2009 04:57 PM
ceiling lighting using electrical receptacle with no switch cedar Electrical 8 02-03-2009 07:00 PM
