Change Wire Size In A Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 11:04 AM   #1
change wire size in a circuit?
Does the code allow you to change wire size in a circuit?
Can I take power from the last box in a 20A #12 circuit and drop down to #14 wire to power a ceiling light?
What I want to do is take power from the 20A circuit, run it to a 3 way switch using #14 from the last outlet box for the lighting portion of the circuit.
mtmisfit is offline   Reply With Quote
Old 10-17-2010, 11:19 AM   #2
Licensed electrician
Rewards Points: 1,506
If you were to do that the entire circuit would need to be downgraded by replacing the 20 amp breaker with a 15 to protect the smallest wire.
Certain circuits are required to be 20 amps.
mtmisfit (10-17-2010)
Old 10-17-2010, 01:07 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
And with this I would add don't do it. There is NO reason to.
Wire size for small outdoor shop?? Danielm Electrical 1 01-12-2010 05:14 PM
Can I change where power enters a branch circuit? RST Electrical 15 07-21-2009 07:38 PM
What size wire and what kind of conduit... epeterson777 Electrical 15 02-21-2009 07:43 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 07:43 PM
