-   -   change wire size in a circuit? (http://www.diychatroom.com/f18/change-wire-size-circuit-84166/)
mtmisfit 10-17-2010 12:04 PM
Does the code allow you to change wire size in a circuit?
Can I take power from the last box in a 20A #12 circuit and drop down to #14 wire to power a ceiling light?
What I want to do is take power from the 20A circuit, run it to a 3 way switch using #14 from the last outlet box for the lighting portion of the circuit.
Jim Port 10-17-2010 12:19 PM
If you were to do that the entire circuit would need to be downgraded by replacing the 20 amp breaker with a 15 to protect the smallest wire.
Certain circuits are required to be 20 amps.
Speedy Petey 10-17-2010 02:07 PM
And with this I would add don't do it. There is NO reason to.
