Change Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 07:29 PM   #1
Change switch
Remodeling bath. Installed new recessed lite using switch that previously controlled vanity. Lite works but not switch. When energized, lite stays on but switch doesn't turn off.
What did I do wrong?
Dollardude is offline   Reply With Quote
Old 01-08-2012, 07:31 PM   #2
Licensed electrician
Rewards Points: 1,766
You apparently hooked the light up to a constant hot.
If you describe the wiring perhaps someone will see the mistake.
Old 01-08-2012, 07:37 PM   #3
Rewards Points: 14,010
Does the incoming power go to the light first then jump off the black down to the light?
Old 01-08-2012, 07:38 PM   #4
joed's Avatar
Rewards Points: 13,332
You hooked it up wrong.
We can't see what you did and we are not psychics so you are going to have to give us a bit more info to be able to identify the problem.
Old 01-08-2012, 08:08 PM   #5
Change Switch
I ran hot wire to lite and then spliced the switch cable at the lite
Old 01-08-2012, 08:19 PM   #6
The black incoming would splice to the white going to the switch. The fixture would connect the black to the black coming up from the switch. Fixture white to incoming white.
The white should be re-identified as a hot with black tape at both ends.
This install would not be code compliant if your area has adopted the 2011 NEC. You need a neutral at the switch.
Dollardude (01-09-2012)
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
