Change Rotation On Dual Speed 115v Motor - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2014, 12:37 AM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by Robert M View Post
Crap... so in other words I'm SOL unless I take it to a motor shop?
If I only plan on using the low speed, is there any way to just cut out the high speed so I am only dealing with the low windings and start windings?
The only way I can see would be to try to reverse install the commutator. Swap the end cap with the commutator 180 degrees.
You would have to mark each wire and extend them to the other end of the motor. the big question is will the windings allow the commutator to be reversed and still spin.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-04-2014, 02:23 PM   #17
Robert M's Avatar
I might go out and try swapping the ends. I saw a video about doing that so I might as well give it a shot. I have lots of wire and terminals to extend them. But, if that doesn't work I think I'm going to fab up a motor bracket and just flip the motor upside down to be done with this. Thanks for all the help guys!
Robert M is offline   Reply With Quote
Old 02-04-2014, 06:46 PM   #18
Rewards Points: 266
This may be a really stupid question, but can the OP just dispense with the connected high speed and start windings and start the motor manually (spin the shaft) in what direction is desired?
ionized is offline   Reply With Quote
Old 02-04-2014, 08:20 PM   #19
Robert M's Avatar
I did that by disconnecting the cap but I really don't want to have to start my drill press by spinning it by hand. I've spend some time today fab'n up a new mount to invert the motor. Depending on how the final outcome is, I may just keep it this way.
Old 02-05-2014, 11:30 AM   #20
Rewards Points: 266
OK, as I read the thread, I recalled seeing a motor or two being started that way as a child. It may have been a been belt sander, bench grinder or the like. It is certainly possible that they were defective and were not really designed to be used that way.
Old 02-05-2014, 12:15 PM   #21
Rewards Points: 338
if it is a belt driven drill press just cross the belt to a figure 8.this way it will run backwards from the motor.
circuitman is online now   Reply With Quote
Old 02-05-2014, 01:30 PM   #22
joed's Avatar
Rewards Points: 11,964
Here are the two speed motor drawings. Same deal. Fiure out which two wires are the start winding and reverse them.
Old 02-05-2014, 01:33 PM   #23
Robert M's Avatar
Spent a few hours yesterday making a new mount to flip the motor and it was all for nothing. All went well up until the test run when I found out the motors output wasn't very much stronger then the crappy HF motor that came with the drill press. On the test run, the motor stalled out trying to drill into 1/8'' steel with a 3/8'' bit. which was the whole purpose of doing the upgrade in the first place. So it looks like I'm going back to the drawing board for this one.
Thank you guys for all the help. I'm sure I'll be back with a few more questions.
Old 02-06-2014, 12:15 PM   #24
Rewards Points: 718
think you have a problem with your drill, i have a 3/4 hp press drill and can make a lot larger holes than that before motor slow down
carmusic is offline   Reply With Quote
Old 02-06-2014, 12:34 PM   #25
Robert M's Avatar
I don't know how it would be a problem with the drill and not the motor but ok...
Old 02-06-2014, 04:43 PM   #26
Oso954's Avatar
Rewards Points: 732
Look at the motor nameplate. It lists the FLA as 11.6- 2.5
If you reduce the amperage when you go to low speed, you are reducing the HP. It is no longer producing the 1.125 HP. My guestimate is you were getting something slightly less than 1/3 HP.
Sounds like an above ground pool/spa motor.
Either run the thing at high speed and use intermediate gearing to slow the speed down to your desired rpm, or get another motor.
Oso954 is online now   Reply With Quote
Old 02-06-2014, 07:18 PM   #27
Robert M's Avatar
New motor is the next step. Thinking about doing the treadmill motor swap if I can get all the components put together for cheap.
Old 02-07-2014, 11:59 AM   #28
Rewards Points: 718
it didnt know that you were using low speed, so motor was actually about 1/4hp like oso954 said
you can get a new 3/4hp motor for 111$ i dont know if that is ok for your budget
http://www.automationdirect.com/adc/.../MTR-P75-1AB18
Dual Ceiling Fan (In Parallel) Speed Control JeffW650 Electrical 5 12-01-2013 12:19 AM
Lennox Furnace Fan Motor Speed gimel HVAC 3 08-06-2012 11:54 AM
wiring a three speed motor . juan devero HVAC 4 03-05-2012 10:57 PM
3 speed blower motor don treat Electrical 0 02-05-2012 12:05 PM
Slowing fan motor speed in air handler Manuel6 HVAC 7 04-17-2007 10:01 AM
