Change Outlet To Hot Add Ceiling Fan With Light - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 12:02 PM   #1
change outlet to hot add ceiling fan with light
outlet has your black and white14/2, switch has three 14/2 going to it. how do I run new ceiling fan to new switch for light and fan.
John
bella3 is offline   Reply With Quote
Old 06-02-2012, 12:13 PM   #2
kevinp22's Avatar
Rewards Points: 252
Bella,
we will need more info to help you. new posters seem to think they have to use as few words as possible so we can decyipher it
anyway, if i understand your post correctly:
1. the receptacle is controlled by a switch and has only one cable going to it
2. the switch box has 3 cables in it - presumably power in, power out to the receptacle, and one other power leg -- probably feeding downstream outlets -- do you know which cable is which?
3. i assume there is no overhead light now?
in short, if this is correct,
1. you will cut a hole in the ceiling and add a fan rated box
2. you will fish 14-3 from the ceiling box to the switch box - you may have to put in a larger swith box with all the stuff going into it (this 14-3 allows you to control the fan and light separately now or in the future)
3. you will have to decide whether you want one switch to control light and fan or one to control each
4. we can walk you through wiring at the switch box
kevinp22 is offline   Reply With Quote
The Following User Says Thank You to kevinp22 For This Useful Post:
bella3 (06-02-2012)
Old 06-02-2012, 12:29 PM   #3
I will have to get back with you
thanks
Combo light switch outlet re-wire question seasidediy Electrical 3 07-21-2011 05:02 AM
Ceiling Fan and light switch conversion pmdockins Electrical 5 07-17-2011 09:52 PM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Tying in wiring to existing ceiling light samson115 Electrical 3 11-22-2009 12:12 PM
