Change Hot Tub Pump From 230v To 120v - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 11:46 AM   #1
Change hot tub pump from 230v to 120v
Have an old hot tub that leaks i would like to use the 230volt pumps on my koi pond. Is it possible to do this and if so how
mcmillenbr is offline   Reply With Quote
Old 08-25-2012, 12:02 PM   #2
Rewards Points: 12,840
Why not just fix the leak?
Old 08-25-2012, 01:25 PM   #3
some can be wired both ways. take the cover off the end of the motor and see if it has alternate wiring on a label inside.
Old 08-25-2012, 04:01 PM   #4
An old Tradesmen
Rewards Points: 6,112
Moved to Electrical forum.
Old 08-25-2012, 04:08 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
If it is in a hot tub it is probably a single voltage motor. You have to look on the rating plate to see if it can be converted.
Old 08-25-2012, 07:50 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I doubt the motor is listed for pond usage...
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
Not sure how to change the draining of sump pump water!!! Please help! tracey11474 Plumbing 10 03-11-2011 11:12 AM
Heat Pump blowing warm air after T-Stat change ericivins HVAC 5 03-04-2011 07:22 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 02:04 PM
