Change Heater Plug - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-20-2012, 06:05 PM   #16
Thanks to you all. I'm convinced not to take the risk.
It just never occurred to me that a light bulb or clock radio would be built that heavily (20 amps).
Thanks again.
Dave
davenk32 is offline   Reply With Quote
Old 12-20-2012, 06:10 PM   #17
TTW
TTW's Avatar
Those small load doohickes are UL listed to be safely connected to a 20 amp circuit.
Could you imagine if we had different plugs and circuits for 5, 10, 15, and 20 amp widgets?
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-20-2012, 07:30 PM   #18
Missouri Bound's Avatar
Originally Posted by davenk32 View Post
Got it. Thanks. How about if I replace the cord and the plug?
Do you want it your way or the right way?
Old 12-20-2012, 09:41 PM   #19
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The heater was designed, listed, and spec'ed to utilize a 30A circuit, the cord and the cord end that came factory installed. Manufacturer specs over-ride the NEC, thus, changing the cord, the cord end, or plugging this into anything other than a 30A circuit, is against code.
The Following User Says Thank You to k_buz For This Useful Post:
frenchelectrican (12-20-2012)
Old 12-21-2012, 07:36 AM   #20
I once saw the results of someone switching a plug on one of those large computer room computers. They did this because an appropriate outlet was not available. They also miswired the plug connecting hot to ground and thus wrecking about $40,000.00 worth of computer equipment.
Note this company had their own in-house electrician and the person could have easily called to have the proper outlet installed. (The person who did this no longer works there.)
Bottom line: Various plugs are on equipment for a reason. Call an electrician and have the proper outlet/circuit installed. It might just be the least expensive route to go! (Not only wrecked equipment, but fire or electrocution possible as well.)
Billy_Bob is offline   Reply With Quote
Old 12-21-2012, 08:34 AM   #21
Rewards Points: 1,548
Incidentally, this is an instance of a mistake made while assembling/rewiring equipment, as opposed to powering equipment without providing proper overcurrent protection. The equipment was damaged immediately when powered on.
In the OPs case, the heater would operate properly on its new circuit. Only if something went wrong with the heater would the bad consequences of using the larger amperage circuit show up.
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
Rotten heater anode rod EdLank Plumbing 6 03-21-2012 11:54 AM
80 Gallon Water Heater Thermostat myowneq Electrical 26 02-13-2012 10:50 AM
Change an American plug to Bristish? Grandmom Appliances 2 12-14-2009 12:23 PM
Glasshouse heater plug melting stuie Electrical 7 04-21-2009 10:54 PM
