Change Heater Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2012, 02:12 PM   #1
Change heater plug
I have a 240v garage heater that came with a NEMA 6-30P plug. I have no more panel space or outlets for it. Can I swap the plug for a 50-10P and plug it in my weldor outlet?
davenk32 is offline   Reply With Quote
Old 12-20-2012, 02:37 PM   #2
Rewards Points: 1,492
It is dangerous and improper to connect an appliance to a circuit of greater amperage than the appliance was intended to have, whether by using an adapter or by swapping the power plug. If the instructions does not specify the maximum amperage circuit for the appliance, the plug that came with the appliance will also imply said maximum amperage, since plugs come in different amperage ratings.
Should physical mishandling, wear and tear, or rust/rot cause damage to an appliance, its being connected to a circuit of too great an amperage could allow unusually large fault currents that create a severe fire hazard.
Old 12-20-2012, 03:22 PM   #3
I'm sorry, I don't understand. The unit uses a max of 20 amps. The breaker is 50 amp. Why is that not a good idea? Thanks.
Old 12-20-2012, 03:32 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,920
Because the breaker does not adequately protect the appliance or its cord from overload.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 12-20-2012, 03:39 PM   #5
Rewards Points: 13,446
With a breaker rated that much above what the heater, and the cord are rated for the the whole cord could be on fire and melting and still not trip the breaker.
Old 12-20-2012, 03:40 PM   #6
Is it a only function of large amperages? If I plug a 2 amp device into a 15 amp circuit wouldn't that cause the same situation?
Old 12-20-2012, 04:20 PM   #7
Your missing the point, if the heater is working perfect then everything will be fine.
If there's ever a short, or anything goes wrong with the heater the power will just keep coming to it until it completly catches on fire. There's no safety factor.
Old 12-20-2012, 04:29 PM   #8
Rewards Points: 150
For example, suppose your cord is rated for 30 Amps, and you use it on a circuit capable of providing 50A. So long as your heater is working properly and drawing just 30A or less, everything's fine.
Now suppose there's a short in the heater (maybe it gets bumped and a couple of the heating elements contact each other) and the total current draw goes up to 45 Amps. The breaker won't trip (45 < 50), but the power cord is now carrying 50% more current than it's rated for.
Since P = I^2 * R, the cord is now dissipating 2.25 times (1.5^2) as much power (heat) as it was designed for, not to mention the sparking taking place at the short.
Dave632 is offline   Reply With Quote
Old 12-20-2012, 04:36 PM   #9
deleted.
Old 12-20-2012, 04:37 PM   #10
Got it. Thanks. How about if I replace the cord and the plug?
Old 12-20-2012, 05:06 PM   #11
Rewards Points: 150
There's internal wiring in the heater, a thermostat or two, probably a couple of switches... all sized based on 30A maximum current.
Old 12-20-2012, 05:12 PM   #12
dmxtothemax's Avatar
Rewards Points: 5,152
Is this code ? or just best practice ?
Whilst I can see the safety aspect of it !
It would be impossable to enforce,
Cause that would mean I couldnt plug a 1 amp load
into a 10 amp circuit !
See what I mean !
dmxtothemax is offline   Reply With Quote
Old 12-20-2012, 05:36 PM   #13
TTW
TTW's Avatar
If you are not using the welder, you could replace the 50 amp breaker with a 30 and change the receptacle.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-20-2012, 05:41 PM   #14
Rewards Points: 150
See what I mean !
But that 1 amp load will be connected to the plug with #16 or #18 wire, not the #28 or #30 wire that can handle 1 amp.
Seasonal example: All the Christmas light strings I've seen lately have the fuses right in the plug, before the skinny wiring that goes from bulb to bulb.
The Following User Says Thank You to Dave632 For This Useful Post:
mpoulton (12-20-2012)
Old 12-20-2012, 05:42 PM   #15
TTW
TTW's Avatar
See what I mean !
because the cord and plug and design of, say, a clock radio, is all made and designed to be plugged into up to a 20 amp circuit.
A heater designed to be plugged into no more than a 30 amp circuit, should not be modified by changing the plug so it could be inserted into a 50 amp circuit.
The Following User Says Thank You to TTW For This Useful Post:
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
Rotten heater anode rod EdLank Plumbing 6 03-21-2012 11:54 AM
80 Gallon Water Heater Thermostat myowneq Electrical 26 02-13-2012 10:50 AM
Change an American plug to Bristish? Grandmom Appliances 2 12-14-2009 12:23 PM
Glasshouse heater plug melting stuie Electrical 7 04-21-2009 10:54 PM
