Change From Gas Wall Oven To Electric - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2009, 09:23 AM   #1
change from gas wall oven to electric
My double gas wall unit oven is 40 years old and must be replace. I prefer electric because I want a combo microwave/oven. A friend told me it would cost me $15,000 (!!!!) to upgrade my kitchen to pull out the gas oven and put in up-to-code electric. How does this make sense?
runjean is offline   Reply With Quote
Old 04-19-2009, 09:35 AM   #2
Civil Engineer
Rewards Points: 4,960
Are you asking how it makes sense that your friend thinks it will cost $15,000, or are you asking how much this forum thinks it might really cost?
If you are asking why your friend thinks it might cost $15,000, you should ask them what the basis of their estimate is. If you want an estimate from the DIY crowd, you should supply some details of the proposed project. For example, what type of combination oven are you considering, how much power does it draw, what capacity (if any) you have in your electrical system.
I recently installed a GE Advantium oven, which is an electric combination microwave/radiant heat unit. Cost of the oven about $1400. I had to replace the wires that fed the old oven, since the Advantium required a higher ampacity circuit. If you hire an electrical contractor, and you do not need to uprate your panel, you should be able to get a new circuit installed for something on the order of $500, unless there are special problems running the wire.
You might have to frame out the kitchen wall cabinet to accept a new oven, especially if the new oven is wider than the old one. There used to be a lot of 24 inch ovens sold, these days most of them are 27, 36 or 48 inch. Add the cost of framing to the price, unless you are going to do it yourself.
Then you need to close off the old gas line. That would be a plumber's job. If you want the pipe completely removed, that would cost more than simply cutting and capping at the source.
Add it all up, doesn't seem to reach anywhere near $15K, but perhaps your friend has expertise and experience in these matters, and could enlighten us all.
Daniel Holzman is online now   Reply With Quote
Old 04-19-2009, 10:22 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
That was a great analysis by DH, Congratulations
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-19-2009, 02:04 PM   #4
I'll do it for $14K and I will throw in the oven for free
If your electrical service will handle the additional load, a 40 or 50 amp, 240 volt circuit probably won't cost more than $500. If you have to upgrade your electrical service to handle the additional load, it probably won't cost more than $2500.
220/221 is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Converting Oven from gas to Electric MicMat Appliances 2 06-18-2008 05:00 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
