Change From Fuses To Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 11:20 PM   #1
change from fuses to circuits
Hi,
We just put a bid in on a house that has fuses, how hard would it be to change over to circuit breakers??
sunrise1* is offline   Reply With Quote
Old 05-31-2012, 11:23 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Its usually not that hard, but each situation is different.
The Following User Says Thank You to k_buz For This Useful Post:
sunrise1* (06-01-2012)
Old 05-31-2012, 11:24 PM   #3
Missouri Bound's Avatar
Not hard at all for a qualified electrician.....just expensive.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 05-31-2012, 11:27 PM   #4
k_buz's Avatar
Call a licensed electrician to give you a quote, then subtract that price from your offer.
The Following 3 Users Say Thank You to k_buz For This Useful Post:
Missouri Bound (05-31-2012), stickboy1375 (06-02-2012), sunrise1* (06-01-2012)
Old 05-31-2012, 11:31 PM   #5
If it has fuses, it's not up to code. It's no doubt a repo, a fixer-upper or some other as-is deal.....is that correct OP?
Old 05-31-2012, 11:37 PM   #6
Electrical Contractor
kbsparky's Avatar
Originally Posted by Missouri Bound View Post
If it has fuses, it's not up to code....
Which Code are you using? The NEC recognizes fuses for overcurrent protection!
Care to back up this assertion?
-KB
The Following 3 Users Say Thank You to kbsparky For This Useful Post:
gregzoll (06-01-2012), JulieMor (06-02-2012), stickboy1375 (06-02-2012)
Old 06-01-2012, 12:54 AM   #7
Rewards Points: 240
A wild guess would be about $2500, in most parts of the U.S. Typically, these fuse-based systems get expanded over the years, and you wind up with a "constellation" of boxes surrounding the main box. All of that should be cleaned up if a breaker panel is installed, but doing so will add to the cost. Note that I'm not certain about K&T wiring -- if the house has that, it may be required by the local authorities to replace it all if you're putting a new panel in. Also, if you're putting a new panel, think about whether or not you need/want to upgrade the service.
fa_f3_20 is offline   Reply With Quote
Old 06-01-2012, 01:04 AM   #8
I don't think it's up to code but I'm not sure, and yes this is an "as is" sale.
Old 06-01-2012, 06:59 AM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
If you are legally buying this house then it IS "up to code", at least in a sense that it has a CofO and there are not open permits or stop work orders.
If it was code then, and nothing has changed, it is code now.
You DO NOT simply "change over to breakers". The whole panel must be replaced, and typically, considering the age of most fuse boxes everything else in the service must be changed as well.
Speedy Petey is online now   Reply With Quote
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
a_lost_shadow (06-01-2012), gregzoll (06-01-2012)
Old 06-01-2012, 08:55 AM   #10
Rewards Points: 6,652
Our house had a fuse panel. The older lady that lived there, kept up the house, but never saw fit to change over to a breaker panel, due to she really did not place a high load on the circuits. My neighbor next door still has a fuse panel, and her house is also no way shape or form a fixer upper or repo.
Fuse panels, as long as they are kept in good working order, are better than breaker panels. The U.S. Navy still uses fuse panels on the sub-panel circuits such as living areas, or office spaces in their older ships, due to they work, and are a lot more reliable than circuit breakers.
Old 06-01-2012, 08:59 AM   #11
Depending on the code cycle, they will require AFCI breakers most likely in your area. I got lucky and ours was paid for by the seller, and all they did was put in the same number of breakers as there was fuses. After we moved in after the close, I went about taking the house from four branch circuits that covered the four quadrants of the house, and breaking it down to a more efficient design. Right now I have five lighting circuits and over 20 branch circuits for other loads, with two each for the dryer & a/c outside condensor.
As long as the rest of the house is sound, work the deal with the sellers to change over the panel, unless it is a foreclosure or short sale, then you may have to work out more into the loan to cover the replacement costs for breaker panel, meter pan, rainhead, permit if needed.
Old 06-02-2012, 08:54 AM   #12
I have to say Greg, this is much more the exception rather than the rule.
AFCI's are typically NOT required during a only service/panel change or upgrade. I have it as fact in NYS and know this is the case in most other areas.
A service change does NOT alter/affect the branch circuits themselves which is what requires AFCI's.
The Following User Says Thank You to Speedy Petey For This Useful Post:
electures (06-02-2012)
Old 06-02-2012, 09:17 AM   #13
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Most municipalities here require fuses for life-safety panelboards in commercial and industrial applications. They are more reliable than circuit breakers.
JulieMor is offline   Reply With Quote
Old 06-02-2012, 12:04 PM   #14
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
SAme in New Jersey.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Speedy Petey (06-02-2012)
Old 06-02-2012, 12:20 PM   #15
k_buz's Avatar
Honestly, I haven't heard of anywhere that does require AFCI's on a simple service change/upgrade. Only when you are adding a new circuit and even then, not all circuits need AFCI's.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
electures (06-02-2012), Speedy Petey (06-02-2012)
Problem w/ two 240v baseboard circuits on single double-pole switch. Skypalace Electrical 18 03-21-2010 05:16 PM
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 12:22 PM
Wiring a relay - 3 independent 15 amp circuits rightim Electrical 6 03-15-2010 12:42 PM
One neutral for two circuits?? TronCarter Electrical 13 01-14-2007 09:21 AM
