Change The Ceiling Light And It's Not As Bright. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 11:10 AM   #1
Change the ceiling light and it's not as bright.
I changed ceiling lights in a bed room and in a hallway.
When I flick the switch, they actually take time to get bright. Especially the one in the hallway, takes about a sec to actually get turned on after I flick the switch. They are very dimmed for the first a couple of minutes, then finally gives out full brightness....
I checked the voltage and it's only about 18.7v...shouldn't it be full 110V just like regular electrical outlets?? (I'm in Canada by the way..)
Please help me and thanks in advance!!
Allen
agapediy is offline   Reply With Quote
Old 06-12-2011, 11:19 AM   #2
Rewards Points: 1,578
Incandescent or fluorescent bulbs? If the first, you've a loose connection or more that needs correcting. If the latter, some CFLs require time to come to full brightness.
bob22 is offline   Reply With Quote
Old 06-12-2011, 11:52 AM   #3
It's CFL but my other light fixtures with CFL works just fine...
I just opened it up to check the connectivity and noticed this light fixture came with three wires and a ground.
One is connected to a live wire(black), another one is connected to a neutral wire (white), and a bare metal wire is obviously connected to a ground wire.
AND I can't figure out where this one last wire should be connected to. It's not labeled or anything and the light still turns on without this being connected.
Any idea??
Old 06-12-2011, 08:20 PM   #4
Rewards Points: 1,494
What do the instructions say the 4'th wire is for?
Can you see where in the fixture the various wires are connected? Post a picture.
How many light bulbs are in the fixture? If more than one and you removed one, does the fixture behave the same?
Old 06-12-2011, 09:36 PM   #5
Rewards Points: 6,652
CFL's can be lower in lumen's, than a incandescent. Different brands can also give off different levels of brightness, or Kelvin degrees. Also, different brands can have shoddier electronic starters than others. I tend to buy from Ace Hardware, Menard's stores, or Lowe's, over buying from Dollar stores or Wal-Crap/Sam's.
