Change 240v To 120v ? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2009, 06:02 PM   #1
Change 240v to 120v ?
Is there an easy way to do the opposite of what you are discussing here? We are taking our electric stove outlet 240 and converting it to a standard 120. Is this an easy job?
clockwork1 is offline   Reply With Quote
Old 09-22-2009, 07:23 PM   #2
Electrical Contractor
kbsparky's Avatar
Fairly easy in many instances. Are you planning on using a gas range in place of an old electric one?
-KB
Old 09-22-2009, 09:48 PM   #3
joed's Avatar
Rewards Points: 12,334
Fairly simple but the #8 or #6 stove cable won't fit in a 20 amp breaker which is the largest size allowed to be used for normal recepatcles.
Old 09-22-2009, 10:16 PM   #4
300zx's Avatar
Post
PigTail #12 Gauge Wire on the range wires .If thats what there wanting someone here will tell them how .Need more info from op 4 wire? 3 wire?
300zx is offline   Reply With Quote
Old 09-23-2009, 07:59 AM   #5
Rewards Points: 1,492
The stove receptacle and power feed must have both neutral and ground in order for you to get 120 volts from it. You may not convert one of two #6 or thinner wires into a neutral if it is not white. A "portable" subpanel with 15 amp and 20 amp breakers and with a plug that fit the existing receptacle would work. The logistics of installing a permanent subpanel and making this accessible can be difficult.
You can downgrade the use of those #8 or #6 wires to 20 amp usage down at the panel, also. Labels would be needed in the panel so someone in the future doesn't reconnect the wires to higher amperage breakers although pigtailing on a 12 gauge wire in order to fit the 20 amp breaker would make this downgrade obvious.
Old 09-23-2009, 11:25 AM   #6
Rewards Points: 126
Good to see some common sense. Just attach #12 jumpers on each end and install a 20 amp breaker in place of the existing range breaker. Then install a single receptacle where the range receptacle was.
If you have service entrance cable (widely used long ago) you will need to pull a new cable.
If it worked before you worked on it. You did something wrong.
Old 09-23-2009, 05:31 PM   #7
Generally, yes.
220/221 is offline   Reply With Quote
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 04:05 PM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
240v appliances with 120V outlets raevenbox Electrical 21 07-02-2009 11:05 AM
Understanding 120V branch loads in 100A 240V system WaldenL Electrical 17 02-17-2009 09:15 AM
Cattle waterer 240V - also need 120v! 2wheelinusa Electrical 6 10-05-2008 06:39 PM
