Chandelier Wiring Problems - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 01:15 PM   #16
Rewards Points: 85
Alright great. I'll hook everything back up the way it was and check it with the bulbs from the old working chandelier. Also just to be %100 safe it is ok if those two wires are mixed up and it appears that it's grounded ok right? Just don't want any safety hazards in my new home.
Thank you guys so much for your help. I have a feeling I'm gonna be on the forum a lot as I fix up my place.
Whyjune1st is offline   Reply With Quote
Old 12-14-2012, 01:21 PM   #17
DIY staff
Rewards Points: 7,174
Not a big deal if the wires are mixed up----the lamp wire with the ridges is the neutral---and goes to the white wire--
Next trip to the store---buy a $4.00 neon tester---
Old 12-14-2012, 01:28 PM   #18
Special User
Rewards Points: 1,230
Your fixture MIGHT be grounded IF the ceiling box is metal and is fed with metal conduit that runs all the way back to the panel. That "should" be the case, but may not be. Without a multimeter, you will not be able to confirm if the ceiling box is actually grounded or not.
Of course, you'll also need to connect the bare copper wire from the fixture, to the green screw I see in your fixture box.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-14-2012, 02:37 PM   #19
Rewards Points: 85
So I bought a multimeter just to be safe. Now can anyone tell me how to use it to check if the ground screw is grounded properly or so I can tell which wire is neutral?
Old 12-14-2012, 02:38 PM   #20
Rewards Points: 85
Pic of multimeter
Old 12-14-2012, 02:46 PM   #21
Special User
Ok, put your meter in the Ohms mode.
With the breaker OFF, and the chandelier disconnected (it will throw off the results), touch one probe to the end of the white wire. Touch the other probe to the metal box.
If zero, or a tiny near-zero value is indicated, you're grounded. This will also confirm the white wire is neutral.
If a very large Ohms value is displayed, you are NOT grounded.
Old 12-14-2012, 03:06 PM   #22
Rewards Points: 85
Thanks for all your help!
Old 12-14-2012, 03:09 PM   #23
Special User
Old 12-14-2012, 04:56 PM   #24
DIY staff
What was it? Bad bulbs or 220 volts?
Old 12-14-2012, 05:05 PM   #25
Rewards Points: 85
Definitely bad bulbs. Going to return them tonight.
The Following User Says Thank You to Whyjune1st For This Useful Post:
oh'mike (12-14-2012)
Old 12-14-2012, 08:22 PM   #26
Rewards Points: 1,542
deleted
heat pump wiring problems zskyman HVAC 17 07-26-2012 04:55 AM
Problems with remote only ceiling fan wiring hscottm Electrical 4 07-17-2012 03:21 PM
Ceiling Fan Wiring Problem kayl Electrical 7 02-23-2011 06:19 PM
Chandelier wiring alacea Electrical 7 11-10-2010 12:32 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
