Chandelier Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2011, 11:44 PM   #1
Question
Chandelier Switch
I have a pull type switch which has 3 wires. Black wire is labeled 2, Yellow wire labeled 1 and blue wire labeled 1. It controls 8 candle lights and one main light. It seems to either control each set of lights or the other or all on. How do you connect them up. Which ones are hot and or common ground?
gmh1419 is offline   Reply With Quote
Old 04-24-2011, 08:01 AM   #2
I suspect that is a multi-function switch. The first pull light on set a lights, the second pull light the other, and possibly a third pull lights all.. The black would be the hot feed into the switch.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
multiple position switch for chandelier TWSpross Electrical 6 02-26-2010 02:13 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
