"Chandelier" Installation Help Please - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 05:20 PM   #1
"Chandelier" installation help please
I am installing a chandelier (looks set-up like a lamp) in my bedroom in an existing spot available to do so. My chandelier is from hobby lobby ( this one to be exact: http://shop.hobbylobby.com/products/...delier-245795/ ).
I examined the place in the ceiling, and I can determine the white wire, the black wire, and the ground copper wire there. However my chandelier has a standard outlet plug and an on off switch on the wire.
My theory is to cut the wire (perhaps also cutting off the switch) and using those two wires, but the chandelier has no ground wire.
I do not know how to proceed, any help would be appreciated.
ColeyK is offline   Reply With Quote
Old 01-15-2013, 06:08 PM   #2
Also I was wondering if to attach the wires to the ceiling wires if I could use duct tape
Old 01-15-2013, 06:17 PM   #3
Rewards Points: 13,468
Duct tape has no use in wiring anything.
Use wire nuts, I believe your going to need yellow nuts.
ColeyK (01-15-2013)
Old 01-15-2013, 08:53 PM   #4
I went out and got them. And I wish I could take a picture and show it off but it looks great and works great. Also solves the mystery of the other light switch. It was meant to be.
Veneer Brick Installation jefsboys Remodeling 3 11-01-2012 06:42 PM
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 11:36 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
