Chandelier And Dimmer Switch Compatibility - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 04:34 PM   #1
Chandelier and dimmer switch compatibility
I just hung my chandelier. I want to hook it up to a dimmer switch. Before doing so, I would like to confirm the compatibility.
The chandelier is low voltage halogen. It has a 12V electronic transformer and states that it is dimmable. The chandelier contains 9 X 20 watt G-9 Bi Pin Base Halogen bulbs. It states the voltage is line voltage (120 volts). My home is on 120V.
The dimmer switch is an electronic dimmer. It supports up to 600 watts and uses a 12 amp triac dimmer.
I think everything checks out, but the whole electronic dimmer vs. magnetic dimmer thing confuses me. If I have a chandelier with a low voltage electronic transformer than don't I need an electronic dimmer? Do the above specs check out?
Thanks in advance.
-Wes
.Capstone is offline   Reply With Quote
Old 11-04-2011, 04:51 PM   #2
Lic Elect/Inspector/CPO
use electronic dimmer
NJMarine is offline   Reply With Quote
Old 11-04-2011, 05:01 PM   #3
So an electronic dimmer can in fact dim a low voltage electronic transformer.
Light switch for chandelier Boz1 Electrical 2 07-11-2011 10:39 PM
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 01:28 PM
Problems with an old 1930 dimmer switch wiring DouglasMcKibbin Electrical 1 02-27-2011 10:33 AM
multiple position switch for chandelier TWSpross Electrical 6 02-26-2010 02:13 AM
Weird problem replacing dimmer switch cdale600 Electrical 9 01-20-2009 08:31 AM
