Chandelier - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 01:49 PM   #1
Chandelier
Trying to hang a chandelier in my daughter's room but having problems. My husband tried hanging a different one in her room last week but something went wrong and sparks were flying in the room and the circuits were tripped. I turned them back on and got a new chandelier. Today, I attempted it again. Turned off circuit breaker, attached ground wire to ground spot, attached black to black and white to white. Turned circuit back on and nothing works.... What am I doing wrong?
christined2003 is offline   Reply With Quote
Old 08-04-2011, 02:06 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Did you check the breaker/fuse to see if it tripped? Is everything else in the room working ok? Check the switch for power.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-04-2011, 02:34 PM   #3
the other lights plugged into the wall sockets in the room work, just the cieling part doesnt
Old 08-04-2011, 03:24 PM   #4
seansy59's Avatar
Rewards Points: 258
WITH POWER OFF
If everything else is working, and just that portion of the ceiling isn't, then those "sparks" might have "melted" something.
Or, it may be something loose. Check the lightswitch if there is one, and double check the wiring leading to that.
You can get a non-contact tester also, and trace for voltage to see where it starts/stops. Just don't touch ANYTHING when the power is on.
seansy59 is offline   Reply With Quote
Tags
chandelier , circuits , ground wire , sparks
Chandelier Wiring Questions Twister Electrical 8 06-18-2011 08:50 AM
Replacing Chandelier Green Grounding Wire? wyjadka Electrical 4 03-24-2011 06:22 PM
chandelier Connection clampion Electrical 3 03-20-2011 09:48 AM
Help for mounting a British chandelier in the US PaliBob Electrical 7 12-16-2009 11:00 PM
heavier chandelier??? frgwtchr Electrical 13 07-25-2009 11:08 AM
