-   -   chain stuck on overhead hanging fluorescent light. (http://www.diychatroom.com/f18/chain-stuck-overhead-hanging-fluorescent-light-85170/)
KatieSue 10-28-2010 11:44 PM
How do I unstick the chain on my fluorescent lighting fixture. I have this light hanging over my washer and dryer.
oberkc 10-29-2010 07:14 AM
My instinct is that you will have to replace the switch on the fixture. I believe these to be readily available at the normal places and that this to be a pretty easy job. If I recall correctly, the switch is simply installed through a hole in the fixture housing, held by a nut over the threaded body. I expect that you will find two wires at the switch. Install them to duplicate the original wiring.
KatieSue 10-29-2010 09:04 PM
Stuck chain ..... cont'd
OK, I took the fixture down (figured if couldn't fix it would need to replace it and would be easier to work on while down). I unscrewed the brass colored screw. The post it was screwed on is like a clear plastic. When I wiggle it, I can see it move with my movements through the slots in the black box that it is in. I am stymied at this point. Do I just go buy a new fixture?
brosea 10-30-2010 04:18 PM
If you remove the flourescent tubes you should have a few small screws that hold on the cover or reflector. Removing this reflector will give you access to the switch. It probably has a black wire going into it and one going out. ***UNPLUG*** light fixture and try to remove these wires ( you may need to cut them as close to the switch as possible. ) Take the switch to a hardware store and see if they have a replacement.
KatieSue 11-01-2010 11:35 AM
Problem with fluorescent fixture ..... cont'd
Well, I took/tore the thing apart ..... no screws to undo. They didn't mean for this thing to be repaired. I think next stop is hardware for new light fixture. Thanks for your suggestions.
