Old 02-04-2010, 08:10 PM   #1
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
CFL in a Range Hood??????
Hello again everyone,
Anyone know if it's safe to use a CFL bulb in a Range Hood?
Sellncars is offline   Reply With Quote
Old 02-04-2010, 08:23 PM   #2
I hope so... I've done this for two years or so..
Big Bob is offline   Reply With Quote
Old 02-04-2010, 09:16 PM   #3
DIY Home owner
had one in mine for over two years, worked till I took my hood out for an over the range microwave.
wherm5150 is offline   Reply With Quote
Old 02-04-2010, 10:51 PM   #4
my mother installed one in our rangehood in 1991 - it lasted until 2007
RTypeEman is offline   Reply With Quote
Old 02-05-2010, 02:10 AM   #5
" Euro " electrician
frenchelectrican's Avatar
I have no issue with my range hood having CFL in there and I know few customer done the same thing they stick in larger "wattage " in there than standard max bulbs from factory however becareful to sizing due some of them may not take CFL at all.
Merci,Marc
Old 02-05-2010, 05:33 PM   #6
Electrical Contractor
kbsparky's Avatar
As long as your hood does not incorporate a dimmer in its wiring, then it should be fine.
Some of the higher-end hoods have multi-position light switches that employ a dimmer. Do not use standard CFLs in such a fixture.
-KB
Old 02-05-2010, 07:27 PM   #7
Sellncars's Avatar
Thanks for all the help again guys. I'll have to go get some more CFL's Tomorrow.
Old 02-06-2010, 09:28 AM   #8
Electrician
SD515's Avatar
Usually, the basic restrictions to using CFL's is if it's being dimmed and physically fitting into the device. There are some CFL's that are dimmable though. Usually for can lights. I put CFL's in my bath fans...had to remove a metal shield and tweak the position of the lamp socket a bit, but all is good. Not necessarily something I recommend to the inexperienced, but in my case, it worked fine.
Kyle
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 08:00 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 11:45 PM
Installing a range hood NewHandyman Electrical 1 08-10-2009 10:42 AM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-16-2008 12:13 AM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 05:43 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
