CFL Flood And Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 02:02 PM   #1
Rewards Points: 121
CFL Flood and Dimmer Switch
Hey Guys, sorry for the back to back questions.
I have 5 hi hats in the kitchen with the CFL Floods (CFL is inside the sealed flood). The are turned on and off with a dimmer.
I am going to assume this is bad as there is a delay before they turn on and then warm up.
What hazards can I encounter here?
Will it kill the dimmer?
Will it kill the CFL floods?
or worse yet - damage the wiring in the walls/ceilings?
Thanks again, your guys kick butt here.
icepal1999 is offline   Reply With Quote
Old 01-30-2014, 02:18 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id say it will be tough on the electronics built into the bulbs
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-30-2014, 02:23 PM   #3
Oso954's Avatar
Rewards Points: 1,652
The first question is are the CFL's dimmable ? They are sold both ways.
If you are attempting to dim a non-dimmable, it will shorten the life of the bulb. (If the packaging did not brag about being dimmable, it probably is not)
With dimmable bulbs, you should start them at full power and dim after they have warmed up.
You will get better performance out of a CFL dimmer as compared to using a standard dimmer.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
plummen (01-30-2014)
Old 01-30-2014, 02:31 PM   #4
Rewards Points: 121
OSO - good point. I don't know, I didn't buy them, the wife did. We do dim them from time to time, mostly hi power while cooking, etc.
They do dim, like I said I more concerned about the delay when turning them on. It's a good 1-2 secs.
Old 01-30-2014, 02:54 PM   #5
Rewards Points: 808
What delay are you referring to? Non-dimmable CFLs don't dim when connected to a dimmer, they remain full output and flicker when the dimmer output diminishes to a point when it's not outputting enough.
IslandGuy is offline   Reply With Quote
Old 01-30-2014, 03:08 PM   #6
Rewards Points: 121
IG - when I first turn them on to full power - no dimming.
Old 01-31-2014, 12:13 PM   #7
Rewards Points: 808
Since you can't dim them, the thing to do is replace the dimmer with a switch. No delay there. I've noticed some CFLs do not come up full bright the instant they're turned on, this is normal for CFLs and has nothing to do with your dimmer. This will not damage your wiring.
Old 01-31-2014, 04:16 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,608
If they are not dimmable CFL's then they most likely will dim to an extent,
But it will be hard on the internal circuits of the CFL's.
And ultimately shorten the life of the lamp.
It will not damage your wiring,
How ever it could damage your dimer.
If you want to keep using them, get dimmable CFL's
and the correct type of dimer.
Do it once !
Do it well !
dmxtothemax is offline   Reply With Quote
Old 01-31-2014, 09:14 PM   #9
Rewards Points: 121
Ok they do dim. I keep them on full power when I am in the kitchen. My wife will dim them from time to time.
My problem is when I turn them on - there is a 1-2 sec delay when turning them on whether it be full power or at half power (dimmed).
From what I gather it seems like it will shorten the life of the bulb more than anything else.
Old 02-01-2014, 01:03 AM   #10
It is normal for CFL's to be slow to come on !
And the older they get the longer it can take,
Quite normal , and probably exsaserbated by the dimmer.
Learn to live with it !
Old 02-01-2014, 06:34 AM   #11
Rewards Points: 121
dmax - I know about them being slow to illuminate.
I want to know if the 1-2 second delay is:
1) Damaging the bulbs
2) Damaging the dimmer
3) or both
Light Switch Reversed.. Up is Off.. down is on caseynshan Electrical 11 07-12-2014 06:10 PM
Installing a dimmer and light switch, also connected to an outlet ... with issues diyanon Electrical 9 12-17-2013 09:56 PM
Problems with dimmer switch BandE Electrical 7 10-16-2012 12:38 PM
Need help with wiring 3 way switch jimgrout Electrical 1 05-13-2010 02:59 PM
wall switch gets hot couchguy Electrical 10 08-16-2008 12:45 AM
